VideoHelp.com Forum
    i played the HDTV movies ,but no sound, AC3 is fine
    where can i find DTS encoder for media center ? Somebody help me
  2. Член BJ_M's Avatar
    you mean decoder ?
    Yes, you mean decoder!! Try PowerDVD.
    yes ,i played the hdtv movies via xbox360, but DTS no sound and my pc's meida center no sound , media player works fine~~~
    My guess, as thegeeman wrote, Try PowerDVD...
  6. Member waheed's Avatar
    You need a software player that supports DTS or has a DTS decoder. MPC also has a DTS decoder.
  7. Member mike909's Avatar
    I have not tried playing a movie yet with DTS through MCE, but the Nvidia purevideo decoder passes the audio directly to your reciever for decoding (through a spdif)...so I don't see why that wouldn't work.
  8. Member Treebeard's Avatar
    I have powerdvd decoder installed on my MCE machine, passes audio to receiver through optical out, DTS works fine as does everything else.
  1. Replies: 1
    Last Post: 19th Apr 2012, 01:37
  2. Media Center support Internet TV
    By Tamer in forum Media Center PC / MediaCenters
    Last Post: 2nd Jan 2010, 21:37
  3. Does this program support DTS?
    By jackand7 in forum SVCD2DVD & VOB2MPG
    Last Post: 26th Mar 2008, 12:39
  4. DTS encoded disk, output to DTS receiver using an HTPC
    By ChipMcC1 in forum Media Center PC / MediaCenters
    Last Post: 18th Nov 2007, 07:06
  5. Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
    By JBredensteiner in forum Media Center PC / MediaCenters
    Last Post: 14th Jul 2007, 01:33
