VideoHelp.com Forum
Results 1 to 13 of 13
    I just finished upgrading my rig including clean install of Windows. I have the latest build of SVCD2DVD. The application immediately closes after the spalsh screen is displayed. No error message received or event logged in Event Viewer. Not experiencing this behavior with any other application. Assistance kindly requested.
  2. Member ChrissyBoy's Avatar
    Did you reinstall SVCD2DVD?
    Yes, I reinstalled it.
  4. Member ChrissyBoy's Avatar
    Ok. Can you please drop me an email and I'll try to get to the bottom of this?
  5. Member CBC's Avatar
    reinstall .net framework too?
    On it's way...
    Yes, reinstalled. Since I did a clean install of Windows on a new drive, I also reinstalled all applications.
    I now see that I have .net framework 1.1 and 2.0. Maybe that's part of the problem?
  9. Member CBC's Avatar
    try uninstalling 2.0. Unfortuntely, SVC2DVD won't work with it yet. You may want to remove both versions, then reinstall 1.1, just to make sure nothing got corrupted.
    That should fix it
    Ok, I uninstalled 1.1 and 2.0; reinstalled 1.1 and the applicable SP1 for net framework. Tried to open SVCD2DVD and again, only got as far as the splashscreen. After displaying for a couple of seconds, it appears to minimize to the taskbar, but it's not there, nor the system tray. Looked in Process Explorer and see no instance of it running.
    Looks like we're back to square 1.
  11. Member CBC's Avatar
    hmm...the only thing I could think of now would be possibly try un/re-installing S2D now that you have the framework part put back in solidly. I'm sure ChrissyBoy may have some ideas too.
    Success!!!! Reinstalled and reregistered and it stays open!
    Many thanks for everyone's help!
  13. Member CBC's Avatar
    yay!
  1. ffmpegX splash screen still showing after registration
    By Le Main Event in forum ffmpegX general discussion
    Last Post: 2nd Apr 2009, 10:11
  2. Trying to create a splash screen for my dvd?
    By wan2no in forum Newbie / General discussions
    Last Post: 4th Dec 2008, 21:11
  3. How to add a splash screen at beginning of avi
    By Overfloating in forum Editing
    Last Post: 20th Jan 2008, 03:37
  4. Background/ Splash screen patch in the UK
    By stavdav in forum DVD & Blu-ray Players
    Last Post: 30th Nov 2007, 10:13
