Normally I cap my VHS tapes with Virtual VCR and PIC MJpeg, encode tha AVI file with CCE Basic and I get a very good and clean DVD, but all this procedure it's a bit tedious and VERY HD space demanding, so I'd like to try some HW MPEG2 encoding card, for acquiring directly from the Sat STB. I would give a shot at the Hauppauge HVR-1300, but any other advice is welcome.
Nik
Checkout avermedia device's .
From my experience , having owned more than 12 different capture device's , the quality from the avermedia hardware is about the best you can get for the price .
Usb2 will alway's give best result's , but pci from this company isn't far behind .
You may also find their cheaper than hauppauge , and have better support as well .
thanks for reply, here in Europe I found that Avermedia has poor support, it's very strong in Asia and Oceania but too weak here.
BTW could you point me to a specific model ?
Nik
Internal Capture Card? Possible to Capture direct to PC?
By Ryutso in forum CapturingReplies: 11Last Post: 25th Jul 2010, 15:58 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 23:20 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
DVD recorder that will record video direct from SDHC card
By madtony in forum DVD & Blu-ray RecordersReplies: 16Last Post: 12th Apr 2009, 11:14 -
Capturing VHS to ALL-IN-WONDER Card
By Smack2k in forum CapturingReplies: 6Last Post: 2nd Dec 2008, 09:20
Statistics
Newest guides
Latest tool updates
New media comments
