VideoHelp.com Forum
Results 1 to 10 of 10
Thread: sticky pan
  1. BuskerAlley.com zoobie's Avatar
    I'm about to try to restore a sticky pan that also has a lake in the foreground. I was thinking of cutting at the stick then crossfading it to the next unsticky part.
    Any tips?
    Thx
    No way you can put a cutaway to break up the pan at that spot ?
    What software do you have available to you ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Stainless steel scrubbing pad and scouring powder
    Sounds like fades and cutaways to other fades and cutaways and some croping and zooming, just like in video editing. Eh, it all kind of depends on what you want and what you have to work with. If there is no live action change the speed maybe or do fades of stills and such.
    IS IT SUPPOSED TO SMOKE LIKE THAT?
  4. BuskerAlley.com zoobie's Avatar
    Maybe use some bleach?
    Yeah, I know...It's impossible to describe.
    Cutting away is not an option.
    Just have to experiment I guess...
  5. Always Watching guns1inger's Avatar
    how many frames does it stick for ?
    does it accelerate after it releases ?
  6. BuskerAlley.com zoobie's Avatar
    It's a 20 second pan
    4 or 5 sticks
    Sticks about one fourth to half a second per stick
    Doesn't appear to accelerate after the stick
    I didn't get to it last night...fell asleep
    Tonights the night I can get in there and experiment
    Just thought I'd ask for tips since this is my first attempt to cure several of these from a cheap travel tripod
    Thx
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    So is it a camera movement problem or a problem on the tape or file? Doesn't really matter, cut it at the last good frame and join it at the next good frame, seems simple huh? If it can't be blended smoothly maybe turn the whole pan into a a jerky stepped frame pan. move for two seconds, pause for two, repeat. Carefully place a pause at a natural bad spot to be able to edit it in or out.
    If you have the software to crop and and put every frame into the timeline you could crop it down to the lowest common veiw and rework it that way.
    This seems more like an artistic challenge, so I am doomed.
  8. BuskerAlley.com zoobie's Avatar
    Well, you forgot the water that's in the foreground. Any cut will show.
    I've thought about it now for a couple of days now.
    1)Trying to speed up just the sticks. No frames dropped.
    2)Good ol' crossfade so the water cuts don't show as much.
    With Vegas you can use what they call supersampling to create transition frames -- basically I *think* as sort of an enhanced morphing. For that sort of thing it can be a bit of a hassle getting it to work right, but I've had acceptable results once or twice. For that matter if the scene's not too complex, might be able to get away with winmorph.
    Another guess might be if you still had access to the original footage to try other means of AD or capture depending on original format.
  10. BuskerAlley.com zoobie's Avatar
    I'll goof with the morph then, too.
    What would be nice is a little ap that determines when the pan has stopped in comparison to the previous frames and basically smooth the whole thing out
    Fortunately, fluid isn't sticky.
  1. Sticky: MVP scripts!
    By cwb in forum Media Center PC / MediaCenters
    Last Post: 15th Sep 2011, 10:11
  2. Sticky threads
    By stiltman in forum Feedback
    Last Post: 27th Jan 2010, 23:49
  3. I know I know its in the sticky but please indulge
    By drathnal in forum DVD Ripping
    Last Post: 22nd Oct 2009, 10:17
  4. Deserves to be a Sticky - Gets my vote
    By bendixG15 in forum Feedback
    Last Post: 11th Apr 2009, 17:34
  5. Sticky layers in Premiere
    By mikal2 in forum Editing
    Last Post: 22nd Mar 2009, 18:41
