VideoHelp.com Forum
  1. Member BleuKousuke's Avatar
    Hi everyone,
    I want to try to make a divx half as big in size without much quality loss. Is it possible with lowering the resolution in half?
    I would like to know more about conversion, so does anyone know a biginning guide or something or advise ?
    Goes digging in videohelp for better movie quality :-/ ?
  2. VH Veteran jimmalenko's Avatar
    Changing the resolution (or frame size) by itself does nothing to change the file size, as filesize = bitrate x running time. However, by changing the frame size, it means that you can lower the bitrate to get a comparable picture quality, which then lowers the file size.
    If in doubt, Google it.
  1. Converting HD (1280x720) to lower resolution for YouTube
    By arjanpublishing in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 31st Dec 2009, 11:17
  2. Where can i learn about video conversion in internet?
    By tendra in forum Video Conversion
    Last Post: 30th Oct 2009, 16:06
  3. Frame resolution is suddenly much lower when capturing?
    By dimitri_vdh in forum Newbie / General discussions
    Last Post: 28th Oct 2008, 16:48
  4. Replies: 6
    Last Post: 20th Aug 2008, 16:09
  5. Half D1 resolution problem
    By sebrame in forum Authoring (DVD)
    Last Post: 30th Jul 2008, 09:18
