VideoHelp.com Forum
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Can TDA edit mpegs and then out put as mpeg instead of vobs?
    What We Do In Life, Echoes In Eternity....
  2. Member gadgetguy's Avatar
    I don't know of a direct way. But if you create the vobs and then start a new project and select them as the source there is an option to save to HDD which will create a mpg.
    Buy My Books
  3. Member ZippyP.'s Avatar
    The problem is that it's an authoring program, although you can do basic editing. You're better off with a dedicated editting program. I use MVW.
  4. Member FulciLives's Avatar
    Once the VOB files are created you can use the freeware program DGIndex which will take the VOB files and output a video file and an audio file.
    So you will have 2 files. The video file (with an M2V extention) and the audio file (which will have AC3, WAV or MPA as the extention according to what format it is ... MPA is aka MP2 audio).
    You can then take the M2V video file and multiplex it with the AC3 or MPA file to create an MPG/MPEG file. WAV audio (also called PCM or LPCM) cannot be used to make an MPG/MPEG file.
    There are various programs with multiplexing capabilites. The one that I use is not freeware (I use MPEG-VCR for this) but I'm sure there are freeware solutions.
    - John "FulciLives" Coleman
  5. Member Cole's Avatar
    Chrissy Boy's Vob2mpg is a simple, free programme for converting authored Vobs to mpeg. I use this, coupled with VideoReDo to edit.
    Cole
  6. That is what TMPGEnc "Media Editor" does. You can input mpegs, do frame accurate edits, and output as mpeg as one choice. Here is a screen that shows your options,
  1. Replies: 8
    Last Post: 6th Nov 2011, 21:02
  2. Free software to split large MPEG-PS file into many small MPEG-PS files?
    By videonewbie22 in forum Newbie / General discussions
    Last Post: 8th Nov 2010, 14:02
  3. Replies: 3
    Last Post: 25th Jul 2010, 17:12
  4. Replies: 0
    Last Post: 27th Nov 2009, 04:40
  5. Replies: 10
    Last Post: 16th Dec 2008, 23:38
