I just picked up a unit and connected it. It lights up (HDD) and shows an L1 on the DVR, but nothing happens when I press any of the buttons. Disk eject, power, nothing. Does this sound right?
Thread: Pioneer DVR-633 Not working?
You can reset the unit as follows. Make sure it is on, then press and hold STOP ( the little black square ) and press STANDBY/ON.
It should turn off with all settings reset.
It did not appear to do anything. HDD light is still on, time is still present and L1 is displayed.
If reset did not turn it off. it does sound bad. Can you return or exchange it? I bought a bad recorder off eBay once but they still allowed me to return it.
[edit] you did the reset from the front panel I assume and not from the remote
Front panel and I got it from a local Rex store so it's going back tomorrow.
Ok, finally got a new one in and so far so good. My question, are DirecTV channels scrambled? I believe they are. If so, I have to setup my DVR a bit differently.
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Removing CPRM on my Pioneer dvd-recorder 633, is this possible?
By mallanikkelsen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jun 2008, 00:27 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02 -
DVR 633 fails to initalize when burning to DVD
By Howardlan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Nov 2007, 17:46
