i used dvd decrypter to rip the movie and videora to convert it but when i watch it on my ipod the video is stretched out to fullsceen when the original i started off with was widescreen? other than that, the prog works perfect. is there a setting i missed????
Thread: VIDEORA q....
all those views and no replies. thats fantastic. i dont suppose anyone would have any suggestions on what progs they use???
Isn't it just to convert it correct aspect ratio by changing the resolution? check the back of the dvd for 4:3,1:85 or 2.35:1.
From the videora ipod faq:
Some suggested starting settings (all settings are for MPEG-4):
iPod only 4:3 (TV) -> 768kbps/320x240
iPod only 16:9 (HDTV, pre-cropped movies), cropped movie at 1.85:1-> 576kbps/320x176
iPod only 2.35:1 (cropped movie) -> 464kbps/320x144
http://www.pspvideo9.com/forums/viewtopic.php?t=2706
or for 2:35:1 movies you should probably also use same settings as 16:9/1.85...if you are not cropping the dvd before converting.
Videora now full of MALWARE!
By Putana in forum DVD RippingReplies: 6Last Post: 4th Oct 2010, 12:25 -
multiepisodes as one file with videora
By Dr.Gee in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2008, 18:56 -
someone explain videora settings
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2007, 05:01 -
videora file size
By Dr.Gee in forum Newbie / General discussionsReplies: 10Last Post: 7th Nov 2007, 09:44 -
Microsoft framework required for videora?
By Dr.Gee in forum Newbie / General discussionsReplies: 6Last Post: 24th Oct 2007, 09:41
Statistics
Newest guides
Latest tool updates
New media comments
