Being not very computer savy, I looked through the site found one method below, is this the easiest
http://www.videohelp.com/srtsubsvirtual.htm
Problem
I use VirtualDub 1.6.11 to open video file avi. Error message "can't locate decompressor for format XVID(unkown). VirtualDub requires a Video for Window(VFR) compatible codec to decompress video. Direct show codec such as those used by Windows Media Player are not suitable.
What to do?
Thanks for all the help.![]()
You install XviD codec.
Thank you XVID codec installed and it is working.
Still looking for best simplest solution on subtitling. Any suggestions are welcome.
Thanks so much
maybe the thefilmmachine or avi2dvd, they supports avi to vcd and subs...but maybe only subs in dvd..not sure.
You if you put the srt and avi file in the same dir, and name them the same (except for the extension) could hope for DirectVobSub filter to pick it up - just open the AVI in TMPGEnc and encode to VCD specs mpg. But I really also would recommend filtering in VirtualDub and frameserve to the encoder.
/Mats
*think* from past research & threads when this has come up, subs support on VCD &/or SVCD is a bit spotty, only a relative few players will display. [none of the players we have will do it, so all I can do is report a quick summary of what I've read]
There seems to be 2 systems that can be used that are in the specs, Phillips I think was the most popular, used to be just one app widely available that didn't work well, Winsubmux is supposed to work.
For VCD there's no switchable subs support at all - it has to be hard subbed.
For SVCD, there is support for selectable subs, but, like you say, not many players support that part of the SVCD standard.
/Mats
How to make DVD with Video .avi and Subtitle .srt?
By lukanino in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2012, 13:51 -
how do i make .srt subtitle files into permanent
By gangers in forum SubtitleReplies: 4Last Post: 28th Apr 2010, 17:41 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 07:51 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 12:43 -
Newbie to d/l apps for video and want to d/l a youtube...easiest/reliable?
By vanc in forum Video ConversionReplies: 4Last Post: 14th Jul 2008, 17:25
