Results 1 to 10 of 10
  1. Member dblue's Avatar
    im trying to copy the screen, so i tryed (Ctrl Alt Print screen) it was working but for some reason its stoped. any idea why its not working now?
  2. Member gadgetguy's Avatar
    CTRL ALT PrintScreen?
    I've used PrintScreen to capture everything and ALT PrintScreen to capture just the active window. What is CTRL ALT PrintScreen supposed to capture?
    Buy My Books
  3. Member p_l's Avatar
    Isn't it either Print Screen (for the whole screen) or ALT + Print Screen (for the active window only)?
  4. Member dblue's Avatar
    the hole point is that its NOT capturing anything. why wont it capture?
  5. Member p_l's Avatar
    Have you tried opening Paint, then selecting Edit | Paste?
  6. Member gadgetguy's Avatar
    OK, let me rephrase. I was not aware that CTRL ALT PrintScreen is SUPPOSED to capture anything. Just using PrintScreen captures everything, ALT PrintScreen captures the active window. Are you saying that these options don't capture anything?
    Buy My Books
  7. VH Veteran jimmalenko's Avatar
    Err ..... because it's not MEANT to capture ?
    I've never heard of Ctrl-Alt-PrntScrn doing anything, unless it's been set up in an image program such as PaintShop Pro as the capture trigger.
    http://www.computerstodayinc.com/printscreen.htm seems to think that only PrntScrn and Alt-PrntScrn do anything, as everyone else has already testified to.
    If in doubt, Google it.
  8. Member dblue's Avatar
    forget about it guys. i found out that my keyborad was F up
    well when you get a new keyboard. make sure to use Print Screen or ALT + Print Screen, not CTRL + ALT + Print Screen
  10. Member Treebeard's Avatar
    using ctrl + alt + print screen does the same thing as the alt + print screen. Just a useless step your taking since the ctrl button doesnt do anything
