VideoHelp.com Forum
    Hey guys
    I just downloaded the first season of a tv show encoded in xvid format. There are 24 episodes and the total size for all is 4.27GB. My question is this:
    If I want to burn all 24 episodes of season 1 onto a dvd how would I go about doing this? I realize that of course there is going to be quality loss, but quality is not too big of a issue for me at this point in time. Please note that I am using using a standard 4.7GB ( hope ths size is correct) to burn the episodes onto.
    Hopefully this is possible, but I am not too sure if it is so I'm hoping someone wouldn't mind giving me an answer as to if it it. Just to note each episode is around 20-23 minutes.
    Video bitrate for each episode: 900
    Audio Bitrate: 112
    Cheers
    9 hours /dvd will look like crap but it is possible, convert to 352x240 mpeg2 ~900kbit/s and 192 kbits audio. use a bitrate calculator for exact size. convert with for example tmpgenc xpress.
    or get a divx/xvid player.
    Thank you very much my friend. Just another question here though.
    I decided instead to split the 24 episodes over 2 dvds. 12 episodes on 1 dvd and the other 12 on another.
    The first 12 episodes total 2.05GB. Now I'm using TMPG PLUS 2.5 to conver the xvid file to a dvd file. So, for example: The first episode has a video bitrate of 900 and an audio bitrate of: 112. When I load TMPG i am using the Wizard and select NTSC low resolution, when I get to the bitrate settings these are the options displayed:
    Video resolution: 320 by 240
    average video bitrate: 6949
    audio bitrate: 384
    Estimated File Size: 4199.91MB
    Percentage of disk capacity = 100%
    This is where I get a bit confused. The video bitrate for the xvid file ( per episode) is 900. So with the above default settings for tmpg it is assuming that I just want that one episode on the DVD. Here is my question: The default bitrate is higher than the xvid bitrate. Obviously, a high-birate does not mean better quality its just using s higher bitrate so it could fit onto 1 dvd with no quality loss. So, is it possible using a bitrate calculator when I am converting the xvid file to dvd such that instead of finding the maximum bitrate with no quality loss that I can find the minimum bitrate when converting to dvd with minimal or no quality loss? Because, since i will be putting around 12 episodes per dvd, I'd like to know for each of the 12 episodes the highest bitrate I can use for each episode so that there is no left-over space on the dvd when I put the 12 episodes on there.
  4. Member steveryan's Avatar
    Simply add up the running times and then use this tool - www.videohelp.com/calc
    He's a liar and a murderer, and I say that with all due respect.
  1. Newbie question for creating a DVD
    By DaBooch in forum Newbie / General discussions
    Last Post: 28th Mar 2010, 17:51
  2. newbie dvd menu question
    By mikeoliver1313 in forum Newbie / General discussions
    Last Post: 2nd May 2008, 05:05
  3. Newbie-Question about DVD Player
    By sohancool in forum Newbie / General discussions
    Last Post: 20th Mar 2008, 23:00
  4. Newbie-DVD format question
    By plemal in forum Newbie / General discussions
    Last Post: 14th Feb 2008, 14:06
  5. TV series ripping to xvid issue (newbie question):
    By Jestrixx in forum DVD Ripping
    Last Post: 11th May 2007, 12:37
