Basically I just bought this new program , its 3 disc. During the install it says insert disc 2. I do but it keep saying insert disc 2.
When I insert disc 2, my pc recognizes as disc two, but still the program says insert disc 2.
Any ideas ?
Thread: Program help
Just for the hell of it I put disc 2 in, at the beganning instead of disc 1.
It says insert disc 1 , the current disc is unrecognised ( no tag )
So is the cd missing something ? Bad cd ?
What program? Have you contacted the manufacturer? It sounds like you have a corrupted install disc.
cosmos , I have not contacted them. Just got home and did not know what was going on.
Tried it on my laptop and it did not work either
90blackcrx,
Do these disks have disk.id files? If so, then check them with notepad and compare. If #2 looks corrupt then rewrite it and save and burn a new CD with the new .id file.
Just a thought,
Chas
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 05:23 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
which program?
By MONSTERTITO in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 12:30 -
Does anyone know a program that does this?
By dcsos in forum AudioReplies: 6Last Post: 10th Jul 2007, 06:05
