VideoHelp.com Forum
    I am noticing noise and other artefacts in some of my DVDs, Is this purely down to the bitrate from the source or is it down to DVD decryptor?? Anyway of cleaning it up?
    commercial dvds?
    backup dvds? how do you backup?
    homemade dvds? how do you make the dvds? what is the source???
    I am burning image files using DVD decryptor.
  4. Member classfour's Avatar
    Bad media??? Check the DVD Media list to
    see what others have to say about the media
    yo're using. Name brand doesn't always
    guarantee it's the best for your burner.
    DVD burner firmware needs update???
    Try lowering your burn speed - If burning an
    8X disc on an 8X or higher burner, burn at 4X.
    (4X at 2X)
    Visit www.nomorecoasters.com or look within
    VideoHelp for burning guides.
    Good Luck.
  1. Removing/toning down digital noise/grain on HD video source.
    By Killer3737 in forum Video Conversion
    Last Post: 27th Jul 2011, 17:37
  2. Digital noise reduction - a warning
    By Quasipal in forum Restoration
    Last Post: 7th Nov 2010, 13:16
  3. Panasonic DMREH75V grinding noise when burning to DVD-R
    By duffy76 in forum DVD & Blu-ray Recorders
    Last Post: 28th Apr 2010, 16:56
  4. Replies: 5
    Last Post: 10th Feb 2008, 05:48
  5. dvd recorder - burning noise's
    By grom in forum Authoring (DVD)
    Last Post: 27th Nov 2007, 13:22
