hi guys i have a question
i have this card with tv-out (geforce 6600 gt) but it clone the screen or do a dual view and i want live playback
I want to see the premiere monitor in a nstc tv directly or playback my timeline for better results.
What can i do or what software o hardware i need for live playback.
Thanks a lot i appreciate your help![]()
Results 1 to 12 of 12
If you have a DV camera you should be able to use it to preview either on the camera screen, or on a TV
Hi alesspunk,
Try also searching and / or posting in the forums over at www.wrigleyvideo.com/videotutorial
It's also an excellent site for Premiere tutorials (and some other Adobe products).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Without firewire box or camera, don't know if possible or not in prem pro2, don't think so in earlier versions -- know you can do it in vegas 6. Microsoft had a beta of something called Windows Media Professional Exhibitor that would display the windowed video full screen on 2nd monitor/TV, but don't know if it'll do anything within Prem.... I know it worked with ATI 2nd monitor, but just checking the site they've got a newer version -- just downloaded so no idea what it will/will not do yet.
http://www.microsoft.com/windows/win...utilities.aspx
thanks for the answers..
well the dv camera i think is good idea, i can used like a vcr and then send the video to the tv.
but maybe is another way... many people used premiere 1.5 or 2.0 for video editing and also HD with the aspect hd plugin.
I supposed they have sd monitor or ntsc/tv for playback job... maybe a pci o something?. I realy dont know!
I'm going to investigate more!.
greetings!
What is your project format? Are you working with HD?Originally Posted by alesspunk
Premiere supports IEEE-1394 monitoring for DV projects.
Uncompressed SDI requires hardware and you monitor off the SDI connection.
HD requires hardware and software additions. See Premiere 3rd party support.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
well i m not working HD, but i m working in dv projects.
The question is ¿How premiere use IEEE-1394 monitoring.? exists a tutorial or link that maybe help me.
and well! i dont know so much about sdi connections and how works maybe you can explain me
thanks man
If you are working in a DV format project, you connect your DV camcorder with IEEE-1394 and Premiere/PPro will capture from or pass through monitor to a TV connected composite or S-Video to the camcorder. Keep in mind that DV camcorders output 0-100 IRE in analog so the TV needs calibration to those levels (7.5% more brightness).Originally Posted by alesspunk
Or you can use a DV transcoder like the Canopus ADVC-110 to do the same thing, but the ADVC can output 7.5-100 IRE so that the TV brightness doesn't need to be adjusted.Recommends: Kiva.org - Loans that change lives.
thanks is working...but i have a problem..
the video and audio has drop frames...
that happens?
I don't have that happen. Since 1999 I've had Premiere 5.0-5.1 and later acquiring and monitoring DV on a 533 MHz PIII and also on a 750MHz PIII Vaio notebook.Originally Posted by alesspunk
Make sure other programs aren't sharing the playback drive. Best to use a physical drive other than the one containing the OS.
Also, turn off anti-virus and other background tasks.Recommends: Kiva.org - Loans that change lives.
"thanks is working...but i have a problem..
the video and audio has drop frames..."
Firewire prob? Lots of posts/threads online reporting prob/solutions depending on firewire & PC setup -- if that might be case, search based on your problem & your hardware.
Got around to checking exhibiter prog mentioned in earlier post -- won't do any good. Using dual monitor setup, perhaps can un-dock monitor in prem and move to 2nd monitor (TV) & maximize? Might not be as accurate as firewire, but could be helpful for colors, which is where the biggest difference is.
And... checking Adam Wilt's site for something else, was reminded that setting up TV monitoring, doesn't hurt to re-check your output, for example on DVD RW. Many devices will put the output into spec 1st (clipping white levels for instance), & hide some of the things you're checking for.
well thanks for the answers again
i resolve the problem
may seen that wasn't render the timeline before playback
here is the link for people that have the same problem
http://www.adobe.com/support/techdocs/326320.html
Premiere Pro CS5 Green Bar, Smooth Playback, Choppy Export
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 27th Jan 2011, 22:38 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Premiere Pro Playback issue
By cabalwars in forum Software PlayingReplies: 2Last Post: 29th Dec 2009, 15:56 -
Video caputres fine in Premiere Pro CS4 but shows up blank on playback
By mroutdoors in forum Video ConversionReplies: 7Last Post: 26th Dec 2009, 13:32 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27
