VideoHelp.com Forum
  1. I downloaded the ProjectX v09.03.01. It always pop up a Startup Error:
    Error while starting Project-X:
    java.lang.Exception:
    commons-net library not accessible! see readme.txt[ii]
    ensure the correct location/calsspath, related to the executed.jar
    at net.sourceforge.dvd.projectx.common.Start.main(Sta rt.java:256)
    Please help. Thanks.
    did you download our projectx compiled?
    http://download.videohelp.com/~downl...ctX_09.3.0.zip
    or the standard java release? where you just run the projectx.jar file.
  3. yes I downloaded the compiled one. After I installed and double click the shortcut, the black window just has a flash. I don't know what's wrong? Thanks.
    works fine here, just tested it. using winxp sp2.
    did you uninstall old version? if you had any installed.
    you can also use the java version, just download and install http://www.java.com/en/download/manual.jsp
    then download the java version and doubleclick on projectx.jar to run it.
  5. It starts perfect now. Thanks, Baldrick.
  6. Originally Posted by huaienli
    I re-installed Windows XP, Java SE (with NetBeans) and Java EE this week and I got the same error above. I made a newbie mistake: in WinZip I dragged the files to a directory which I named myself (Project-X). I should have used the Extract button in WinZip, so the directory structure would have been the same as in the .zip file (by dragging no directories will be created). =)
  1. Help with ProjectX and Subtitles
    By cyberfizz in forum DVB / HDTV
    Last Post: 26th Jan 2012, 11:38
  2. Where to start? I'm a amateur photographer and I want to start out in video
    By James Wright in forum Newbie / General discussions
    Last Post: 17th Jan 2011, 17:58
  3. ProjectX 0.90.4.00b32
    By newstrength in forum DVB / HDTV
    Last Post: 16th May 2010, 13:10
  4. ProjectX demux help
    By delpis in forum Newbie / General discussions
    Last Post: 8th Jun 2007, 01:51
  5. ProjectX - possible to patch?
    By netmask56 in forum DVB / HDTV
    Last Post: 21st May 2007, 00:18
