VideoHelp.com Forum
    Hi guys. I was trying the convertxtodvd program and its really good. I could pass from avi to dvd and creating a menu. But when i add the subtitles on the options it says it is all correct but when encoding subtitles doesnt appear. I name it as the same as the avi name but still doesnt appear on the final files
    Any one knows how to make subs work correctly???
    Thanks!
    Did you add the subtitle in convertxtodvd?,
    You wont see any subs while encoding.
    Then when you play it on your dvd player you probably need to enable the subtitle by click on the subtitle button on your remote control.
    yes. And it also the program add me the subtitle automaticaly if the sub name is the same from the avi name
    I had this problem befor.. orcorse Baldrick gave me a helpful progrem to check subs cant remember witch one. but any way my Subs u had had a invaild line in the subs so i used this program i did some check on it. siad like error in 4 lines then it has a thing to attempt to fix them. then i just resaved them in a new .srt
    also i just redownloaded a new set lol much more simpler :P
  1. subtitles and convertxtodvd
    By babeflover in forum Subtitle
    Last Post: 30th Nov 2010, 21:24
  2. Subtitles and ConvertXtoDVD 3
    By sissyfoot in forum Subtitle
    Last Post: 10th Nov 2009, 22:14
  3. Heb Subtitles in ConvertxtoDVD
    By eliqush in forum Subtitle
    Last Post: 15th Jul 2009, 02:10
  4. Subtitles in ConvertxToDVD
    By lanooz in forum Authoring (DVD)
    Last Post: 4th Nov 2008, 09:07
  5. No subtitles with convertxtodvd !!
    By hilario in forum Subtitle
    Last Post: 9th Jun 2007, 18:04
