I was just wondering why we can't use arrow keys on VCD menus? I know it isn't possible, but all the post I have read just say it can't. I want to know the real technical reason why it isn't possible. Another quick question, DVD menus are written in XML correct?
Thanks in advance!!!
VCDs can't use the arrow keys because the format wasn't designed for them. It's like saying why your Hi-Fi remote doesn't work on your DVD player. VCDs predate DVDs by many years.
DVD menus are not written in XML. In fact, VCD menus are not written in XML either (VCDs are OLDER than XML -- and ?even HTML).
VCDImager just uses XML as a scripting language to describe how you want your VCD to be authored. There is no XML on the actual VCD itself (and the same is true for DVD).
Regards.
Michael Tam
w: Morsels of Evidence
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
VCD on a DVD with menu?
By capman21 in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 10:00 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
Statistics
Newest guides
Latest tool updates
New media comments
