i try to rip a self-burned dvd to harddrive with dvd decrypter so i can edit it and burn it on a fresh copy, and i received the following error message from dvd decrypter during the process
I/OError!
Device: [1:0:0]_NEC DVD_RW ND-3550A 1.05 (D(ATA)
ScsiStatus:0x02
Interpretation: Check Condition
CDB:28 00 00 12 04 B0 00 00 01 00
Interpretation: Read (10) - Sector: 1246384
Sense Area: F0 00 03 13 04 B0 0A 00 00 00 00 11 00 00 00 00 00
Interpretation: Unrecovered Read Error
do anyone know what the problem is
any help would be appreciated
Thread: problem ripping dvd to harddrive
it's probably the brand of dvd media that you used. usually cheap dvd media will have problems with the files being read back. try ripping the disc with the latest DVDFAB DECRYPTER.
i have tried dvdfab decrypter, it took really long time like 3hrs and the file came out to be incomplete
so u saying its hardware problem not the something wrong with the software?
no it is not a software problem but it's probably the brand of dvd disc that you used. cheap dvd media will result in the problem that you have.Originally Posted by yuan861118
you could try using another dvdrom/dvd burner to try to get the disc to be read back correctly. NEC drives are known not to be good readers.
Ripping DVD To harddrive in one hq file
By videodirector in forum DVD RippingReplies: 10Last Post: 15th May 2009, 10:56 -
Need some help with new ps3 harddrive problem
By f-zer0 in forum ComputerReplies: 5Last Post: 22nd Jul 2008, 06:38 -
the weirdest harddrive/ripping problem ive ever seen
By ted demen in forum Newbie / General discussionsReplies: 12Last Post: 10th Feb 2008, 21:20 -
DVD ripping problem
By efiste2 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 16:07 -
DVD--HardDrive problem
By electricsguy in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 04:14
Statistics
Newest guides
Latest tool updates
New media comments
(ATA)
