Hi,
I’ve been given the task by my wife of archiving episodes of LOST from my Comcast PVR (Motorola Dual-Tuner DVR High-Definition Set-Top DCT6412) to DVD. After reading much “stuff” from the web and trying about a million programs, I’ve pretty much got a system down. I was wondering if you could set me straight on a couple of stumbling points I have.
The Goal: Archive lost episodes I have recorded both in HIDEF and standard to DVR. Either normal def or hidef but hidef is preferred.
Sub goal: Get the wife to stop bugging me about the PVR filling up.
Problem#1: I’m using CAPDVHS to create the transport stream. Using a ThinkPad p4 2GHZ with 512 RAM and onboard firewire to capture from my Motorola box. I am playing an episode that has been previously recorded and stored on my PVR and capturing it from the firewire port. It would seem that if I play a 63 minute show (HIDEF), it plays normal 63 minutes but I only record about 39 minutes of it even though I’m watching it and the CAPDVHS is running for the full 63 minutes. Is my PC too slow? I even set the timer to 90 minutes and still only get 39 minutes. Is this a Motorola thing? If I stream the low def version of the same episode, I get the full 63 minutes.
Problem #2: related to #1 if I start another capture to get the rest of the show, I don’t have much luck doing the copy/b thing to combine the .ts files so HDTV2DVD can author it.
Problem #3: If I choose to burn the standard def version, HDTV2DVD super encodes the .ts so that it looks really bad. Any plans on letting HDTV2DVD author standard def (checkbox)??? PLEASE
Problem #4: I’m running 1600x1200 resolutions on my notebook. The window is too big for my screen. It does not fit. I can’t seem to resize so I have to undock the asset window to get it on the screen. It disappears as soon as I lose focus. Often goes behind the main app (disappears) if when it’s not docked. The only way to correct is to stop and re-start the app. Makes it super difficult to drag .ts files from explorer and still be able to reach the go button.
Other than that, your program does exactly what I need it to do. Thanks for filling the need for something like this. Sorry for bugging you on a free program. Let me know where I can make a donation to keep the good stuff coming. I can see the light at the end of the tunnel. Frank H
Results 1 to 18 of 18
Thread: HDTV2DVD and CAPDVHS questions
One at a time:
Can you show me a log from HDTV2DVD on the ThinkPad? I have a theory about the 39/63 minute thing.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
************************* ProjectMetaData **************************
<HDTV2DVD DateTime="2/3/2006 4:58:15 PM"><AssetSet><Asset ID="02e853bc-0b67-4f63-862f-3556e012f298" Path="\\Orion-p3\lost" Filename="man of science_Fixed.ts" /></AssetSet><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="" NeroWriteSpeed="" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></HDTV2DVD>
Processing assets for DVD creation
=================== AV Details ===================
file=\\Orion-p3\lost\man of science_Fixed.ts
FormatName=mpegts
Num_Frames=143561
DurationInSecs=2395
Duration=00:39:55.0
VideoCodec=mpeg2video
Width=1280
Height=720
Standard=NTSC (59.94fps)
BitRate=14344
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=384
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
HDTV2DVDMPG: 7800kbs
Leaving source audio alone.
Using high bitrate matrices
Pass 1/1: Processing man of science_Fixed.ts
16:58:19: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
16:58:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-vhook
16:58:19: built on Sep 23 2005 15:20:26, gcc: 3.2.3 (mingw special 20030504-1)
16:58:19: Input #0, mpegts, from '\\Orion-p3\lost\man of science_Fixed.ts':
16:58:19: Duration: 00:39:55.0, start: 81896.865100, bitrate: 14344 kb/s
16:58:19: Stream #0.0[0x11], 59.94 fps: Video: mpeg2video, yuv420p, 1280x720, 13550 kb/s
16:58:19: Stream #0.1[0x14]: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
16:58:19: Output #0, dvd, to '\\Orion-p3\lost\man of science_Fixed_S2D.mpg':
16:58:19: Stream #0.0, -1.#J fps: Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 7800 kb/s
16:58:19: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
16:58:19: Stream mapping:
16:58:19: Stream #0.0 -> #0.0
16:58:19: Stream #0.1 -> #0.1
16:58:19: Warning, QMAT_SHIFT is larger then 21, overflows possible
16:59:04: [mpeg2video @ 00712860]rc buffer underflow
17:08:32: [mpeg2video @ 00712860]rc buffer underflow
17:08:33: [dvd @ 00411BE4]buffer underflow
17:08:34: [mpeg2video @ 00712860]rc buffer underflow
17:08:35: [dvd @ 00411BE4]buffer underflow
17:11:22: [dvd @ 00411BE4]buffer underflow
17:17:17: [mpeg2video @ 00712860]rc buffer underflow
17:33:55: [mpeg2video @ 00712860]rc buffer underflow
18:17:02: [mpeg2video @ 00712860]rc buffer underflow
18:26:54: [mpeg2video @ 00712860]rc buffer underflow
20:39:08: video:2221975kB audio:112158kB global headers:0kB muxing overhead 1.757010%
20:39:08: HDTV2DVDMPG: done.
20:39:08: Done: Processing assets for DVD creation
Authoring DVD Folders
20:39:09: Creating TitleSet # 1
20:39:09: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
20:39:09: -->: DVDFolders creating VTS
20:39:09: -->: VTS 01
20:39:09:
DVD Folders: Processing \\Orion-p3\lost\man of science_Fixed_S2D.mpg...
21:51:45:
21:52:43:
21:52:43: Finalising DVD...
21:52:43: SVCD2DVD: DVDfolders
21:52:43: -->: DVDFolders creating table of contents
21:52:43: scanning \\Orion-p3\lost\HDTV2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
21:52:44: Finalising DVD...Done
21:52:44: Done: Authoring DVD Folders -
Its the top of the log i need to see.
Thanks for the assist! That is the whole file. I checked other logs a s well and they all start with
Is there something else specifially you need to see? F -
ok. Sorry about that.
I'm slightly confused but is \\Orion-p3 on your laptop or is that an external drive?
What is the filesystem format of the drive you are capturing to? And is that the \\Orion-p3 share?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
orion-p3 is a networked drive on a different machine. Its an xp machine with lots of space but sadly, no horsepower. My laptop is fine with hp but no space. Frank
FAT, FAT32 or NTFS?What is the filesystem format of the drive you are capturing to?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
FAT32 has a file limit of 4GB. i.e. a single file can be no more that 4GB.... So i suspect that when you are capturing HD you are going beyond that limit, hence the trucation.
Fat32 was what was killing my Hidef captures. I have harvested and burned my first Lost episode. Turned out Great! Thanks for the help. ANy plans for low def capturing. I have some car shows in nornal def I wouldlike to burn as well. If I burn them now, the picture is bad. Thanks again FRank
Good news. Can i see a log from the SD run?
Sure!! Here it is.
<HDTV2DVD DateTime="1/30/2006 7:25:17 AM"><AssetSet><Asset ID="606ebf5d-4336-4947-b66d-39ecf2e7d4f0" Path="G:\dvr firewire" Filename="fire and water_Fixed.ts" /></AssetSet><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="" NeroWriteSpeed="" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></HDTV2DVD>
file=G:\dvr firewire\fire and water_Fixed.ts
FormatName=mpegts
Num_Frames=-2147483648
DurationInSecs=-2147483648
Duration=-577014:-32:-22.-7
Width=704
Height=480
Standard=NTSC
BitRate=0
AudioStreamCount=1
Audio1Codec=ac3
Audio1BitRate=192
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
HDTV2DVDMPG: 0kbs
Pass 1/1: Processing fire and water_Fixed.ts
07:25:18: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
07:25:18: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-vhook
07:25:18: built on Sep 23 2005 15:20:26, gcc: 3.2.3 (mingw special 20030504-1)
07:25:18: Input #0, mpegts, from 'G:\dvr firewire\fire and water_Fixed.ts':
07:25:18: Duration: N/A, start: 39782.844100, bitrate: N/A
07:25:18: Stream #0.0[0x11], 29.97 fps: Video: mpeg2video, yuv420p, 704x480, 15000 kb/s
07:25:18: Stream #0.1[0x14]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
07:25:18: Output #0, dvd, to 'G:\dvr firewire\fire and water_Fixed_S2D.mpg':
07:25:18: Stream #0.0, -1.#J fps: Video: mpeg2video (hq), yuv420p, 352x480, q=1-31
07:25:18: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s
07:25:18: Stream mapping:
07:25:18: Stream #0.0 -> #0.0
07:25:18: Stream #0.1 -> #0.1
07:25:18: Warning, QMAT_SHIFT is larger then 21, overflows possible
08:07:03: video:176107kB audio:88558kB global headers:0kB muxing overhead 9.762165%
08:07:04: HDTV2DVDMPG: done.
08:07:04: Done: Processing assets for DVD creation
08:07:05: Creating TitleSet # 1
08:07:06: SVCD2DVD: DVDfolders
08:07:06: -->: DVDFolders creating VTS
08:07:06: -->: VTS 01
08:07:06:
DVD Folders: Processing G:\dvr firewire\fire and water_Fixed_S2D.mpg...
08:08:26:
08:09:26:
08:09:27: Finalising DVD...
08:09:30: SVCD2DVD: DVDfolders
08:09:30: -->: DVDFolders creating table of contents
08:09:30: scanning G:\dvr firewire\HDTV2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
08:09:34: Finalising DVD...Done
08:09:34: Done: Authoring DVD Folders -
Arh yes. The source has a wraparound PTS. I have a fix for this which is due for release when i get a moment. Email me & I'll send it to you.
ChrissyBoy, is your 6412 a phase II or phase III? I have a phase II but the firewire porst is disabled. Is there a way, that you know of that is, that I can enable it? I, too, have found that the internal HDD is just not enough space and fills up pretty quickly.
I have been reading around but I'm not getting much info on how to actually enable the port. I think the usb ports are turned off as well...Can I network the unit with the ethernet port with a crossover cable and edit the settings that way? ... just a thought...Boy do I love my avatar! -
tsantsa: I don't have one, so i have no idea. fhelm does so he may be able to help you... If you hear nothing from this thread maybe drop him a PM?
Oh jeez...I don't know why I typed your name ChrissyBoy!!! lol lol Im sorry about that!
Trouble with aspect ratio and resolution with CapDVHS
By ckp in forum CapturingReplies: 69Last Post: 1st Jul 2011, 13:53 -
Capturing Into *.MOV Format With CapDVHS
By eddiegnz1 in forum DVB / HDTVReplies: 7Last Post: 17th May 2011, 23:44 -
Caputuring HD TV via firewire CAPDVHS on Windows 7?
By Strawson in forum CapturingReplies: 3Last Post: 16th Oct 2010, 09:31 -
CapDVHS question
By dbanimal in forum CapturingReplies: 4Last Post: 6th Jul 2010, 10:54 -
Capturing with CapDVHS via firewire
By tampa_man_33 in forum CapturingReplies: 7Last Post: 10th Nov 2008, 00:51
