I'm trying to use the dvd4 tool in ffmpegx (v0.0.9u r2 Dec 4, 2005). The dvd.vob file is 6.43 GB. Files dvd.ac3 (440 MB) and dvd.m2v (3.06 GB) are created. The process then fails in mplex with:
**ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern [...]/dvd.mpg
I see this problem has been posted before, but not recently. Based on the replies to those postings I tried using the mux tool to complete the process. That also fails in mplex in the same way unless I select the Split mpg option. In this case it produces dvd-1.mpg ... dvd-24.mpg and then says it's finished. No VIDEO_TS folder is created. The last output in the console window is from mplex, so it seems not to be attempting to author it at all.
I'm new to this - just registered ffmpegx specifically so I could use the dvd4 tool - any help would be most welcome!
Ok, well it seems it was something funny about the .vob file. I'd used yade to select a track from a dvd and the track included a bunch of little dummy chapters. When I was more selective the problem went away.
I'm experiencing the exact same problem. After ~30 mins, I only get MOVIE.ac3 but no VIDEO_TS folder. Using ffmpegX 0.09u r2. Original VOB is 5.57 GB in size.
Where do you see the mplex error?
In the progress window, click the info tag next to the progress bar; a window opens showing you the console output for the process.[/quote]
Ok. Unfortunately, every time I click on that "i" button, Progress consumes 100% CPU for several minutes, then crashes.
I exeperience exactly the same problem.
And I don't find any solutions.
I got the .vob file from 0seX (0.1).
What do you mean with "more selective" ?
Where is the "split" option ?
(ffmpeX 0.0.9v)
Thank you for paying attention.
Open source TS mux/demux tool
By rrrip in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 09:39 -
Demux/Mux Tool
By mltwitz in forum DVD RippingReplies: 3Last Post: 7th Dec 2010, 10:39 -
output filename of mux tool
By fanglyfish in forum ffmpegX general discussionReplies: 2Last Post: 25th Jul 2008, 23:06 -
New? Tool - Besweet Mux Wizzard
By Soopafresh in forum AudioReplies: 1Last Post: 14th Jul 2007, 11:52 -
Problem with dvd4 tool
By barskey in forum ffmpegX general discussionReplies: 2Last Post: 5th May 2007, 20:32
