Ok, I just bought a pvr 150 and upgraded from my wintv go. Now, when I start photoshop or my scanner programs, it tells me NUVtwain.dll is missing and I looked on the cd I got with my capture card, and there isnt one there.
Anyone know where I could get the dll file?
I had a dream about insomnia the other night...
When I woke up.. I thought.. I can finally get some sleep
I did google it but I didnt know I could use that driver
Since mine is not usb. Thanks a bunch!
Run Registry Editor try searching for NUVtwain.dll and remove the key to that file which was for WinTV USB or Dazzle DVC 50/80 and add on the dll will not do you any good.
Format reinstall Windows.
I had the same problem.
I solved it using the download link on this post:
http://tchipp.blogspot.com/2009/11/p...-manquant.html
Bye.
Hauppauge 150: Odd Problem With Capturing
By Tom Saurus in forum CapturingReplies: 13Last Post: 13th Apr 2011, 19:42 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum CapturingReplies: 0Last Post: 12th Jun 2010, 11:22 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum CapturingReplies: 11Last Post: 14th Mar 2008, 10:03 -
Hauppauge 150, good or bad?
By SerbianBoss in forum CapturingReplies: 21Last Post: 4th Dec 2007, 09:24 -
You folks were right, Hauppauge 150..
By The Fred in forum CapturingReplies: 3Last Post: 8th May 2007, 13:39
