I just updated the firmware on my DVD Player (Onkyo DV-SP502S) to play MPEG4 (divx/Xvid). I have Nero 6 and would like to know what settings I should choose to burn the avi files to :
1) a regular CD?
2) a DVD?
Thanks in advance
I'll post a guide I created a while back on these thing's soon .
You may only need the burning part , but the whole thing will be up for all use then .
Keep an eye on the guide's section , it'll be up in 2 day's .
Use the DVD-ROM (ISO) template of Nero Burning. Just drag your files to the compilation window. Burn.
If you standalone supports avi files, then all you have to do is burn the files as data.
Google is your Friend
Ah ok so the ISO template for either DVD or CD will do the job. Great thanks for the replies.
I believe the UDF and ISO/UDF templates will work too. Don't use Multisession -- that confuses a lot of players.Originally Posted by mr_jbloggs
A lot of players won't like UDF. No point unless your avi is >= 2GB's anyway.
Hello!,
I would like to know where did you get or find the firmware update for your onkyo player?.
I have not found a place or a site where these firmwares could be found.
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 06:44 -
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 13Last Post: 14th May 2008, 17:12 -
Fast DVD -> MPEG4 (DivX/XviD)
By zmaki in forum DVD RippingReplies: 2Last Post: 28th Feb 2008, 14:50 -
What's best to burn to DVD: XVID, DIVX, AVI?
By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 07:35 -
Why won't image burn allow me to write AVI?
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 15th Nov 2007, 17:26
