Hi ! I've got a question which might be simple for some of you and which apparently has not been asked yet.
When you have a DMR E95H or DMR-E85 (i don't know which one exactly, it's for a friend) you can make DVD using the menu sample(s) which is(are) incorporated in the DVD Recorder. But how can you make your own ? Do you just need to take the Hard Drive out in order to plug it in your computer to change of few .gif, .jpg or else files ?
Thanks in advance for your answers !
piocki
After you finalize your dvd you can edit those files & put on a new menu if you want. Is that what you are asking? You can import Panasonic files to your hd too, just write to a disk & put it in your computer.
The panasonic menus look nice.
I doubt there is anything on the HDD (GIF , MPEG files) that you can change to have customed menu.
This unit allows to put in a brand new HDD (from Frys for example), format it and it just works as with the HDD shipped with the unit.
This says that there is no software or data on the HDD that the unit relies on to operate. And this is a very nice feature.
I agree with handyman, if you want to customize the menu, simply burn a DVD-R and then copy it to the computer and re-author with some authoring software.ktnwin - PATIENCE
Thanks for the answers, i guess it's better for the sake of my DVD recorder b/c i won't have to unplug my Hard Drive...
[Are you saying that with either of these models..I can replace the hard drive in them..maybe one with more storage?is there software needed to complete this?
quote="ktnwin"]I doubt there is anything on the HDD (GIF , MPEG files) that you can change to have customed menu.
I agree with handyman, if you want to customize the menu, simply burn a DVD-R and then copy it to the computer and re-author with some authoring software.[/quote]
Panasonic DMR EH50 - HDD Upgrade
By agdex in forum DVD & Blu-ray RecordersReplies: 1Last Post: 21st Jul 2011, 13:49 -
Issue with Panasonic DVD-Recorder DMR-EH55
By chudbeagle69 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 16th Aug 2010, 12:56 -
New HD TV seems to override Panasonic DMR-EH55S's DVD recorder's tuner
By Marshfish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Jul 2009, 10:40 -
Copying DivX to HDD on a Panasonic DMR-EH57
By Ouchies in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 06:05 -
More Panasonic DMR E85 problems HELP!!!!!!!
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 16Last Post: 20th May 2007, 18:36
