Hi, I am evaluating FFmpegX (0.0.9u r2) for encoding files to 3gp (h263, amr sound).
I discovered that after compresion the file is 2times longer and
- has not audio
- has "white" second half
I tested default setting (.3gp) and also custom settings (with and withoud - High quality and 2-pass encoding)
Any Idea what is happening? Any help?
Thank you very much.
Here is the log:
Thu Jan 19 07:52:01 CET 2006
Mac OSX static build for ffmpegX
Input #0, mov,mp4,m4a,3gp,3g2, from '/Users/jiri/Documents/Prace/video/3gp/BABD10351UK-Bin_Liner_20s01-origZaloha.3gp':
Duration: 00:00:21.1, start: 0.000000, bitrate: 131 kb/s
Stream #0.0, 12.00 fps: Video: mpeg4, yuv420p, 176x144
Stream #0.1: Audio: aac, 16000 Hz, stereo
Output #0, 3gp, to '/Users/jiri/Documents/Prace/video/3gp/BABD10351UK-Bin_Liner_20s01-origZaloha.3gp.ff.3gp':
Stream #0.0, nan fps: Video: h263, yuv420p, 176x144, q=2-24, pass 1, 74 kb/s
Stream #0.1: Audio: amr_nb, 8000 Hz, mono, 8 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[h263 @ 0x444b70]removing common factors from framerate
[h263 @ 0x444b70]warning, clipping 1 dct coefficients to -127..127
bench: utime=3.183s
video:265kB audio:43kB global headers:0kB muxing overhead 3.428139%
Stream #0.0, nan fps: Video: h263, yuv420p, 176x144, q=2-24, pass 2, 74 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:198kB audio:43kB global headers:0kB muxing overhead 4.379378%
bench: utime=3.208s
Encoding completed on Thu Jan 19 07:52:13 CET 2006
It is possibly linked to the audio resampling from 16000Hz to 8000Hz. Can you email me a clip (with yousendit.com) to major4@mac.com for testing?
3GP file size
By Jean777 in forum AudioReplies: 3Last Post: 24th Feb 2010, 16:36 -
corruptd .3gp file
By stikolyz in forum Video ConversionReplies: 0Last Post: 20th Jan 2010, 08:45 -
FFMPEG 3gp conversion
By diskontrol in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:50 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 11:04
Statistics
Newest guides
Latest tool updates
New media comments
