I want to capture the video effect that happens when I scrub through my footage in Premiere.
I know I can simply connect my DV camera as the capture device and simply record the output - but here's the rub: my DV camera is an older consumer model, and lately, it's been showing some glitchy errors when recording and playback. I want to capture a clean signal, and I'm afraid the camera will record too much digital noise to be of any use.
What I'd like to do is either setup some kind of "virtual" DV capture device (similar to the virtual MIDI devices like the loopback) :: OR :: link my two computers together via firewire, having one act as the DV capture device.
Are any of these two options feasible, and how would I go about that? Is there another way to do this that I'm not thinking of?
Thanks!
-c
The second option should work, but have you tried the DV cam? Use several takes if necessary.
For option 2 just use WinDV for recording on the second machine. Then import the file.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
edDV:
Is there some special setup to link the two computers? I tried simply connecting both of them via firewire cable, but WinDV doesn't "see" the other computer as a video device.
Thanks!
Do you have Premiere set up to realtime monitor on the IEEE-1394 output? Any full Premiere from v5.1 does that. Check your instructions. I don't have it at this location.Originally Posted by itchi23
The DV camcorder should see your timeline when connected with IEEE-1394.Recommends: Kiva.org - Loans that change lives.
Capture device
By ingeborgdot in forum CapturingReplies: 7Last Post: 11th Sep 2011, 20:02 -
Capture Device
By NMeade in forum CapturingReplies: 7Last Post: 24th Feb 2011, 17:23 -
Virtual video capture device?
By plugues in forum Video StreamingReplies: 2Last Post: 13th Jul 2010, 19:28 -
Getting Adobe Premiere to read Capture Device
By ineedatalent in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2009, 12:55 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum CapturingReplies: 11Last Post: 5th Oct 2007, 04:31
Statistics
Newest guides
Latest tool updates
New media comments
