VideoHelp.com Forum
  1. I just bought a dvd writer for my laptop off ebay, I want to check if it has the technical specs,like drive speed, burning speed etc, that the seller said it would have. How would do I do that?? What software do I use?
    thanks
  2. Member gadgetguy's Avatar
    Google is your friend.
    Search for the Make/Model of the burner.
    Or try the manufacturers website (although if it's no longer in production it might be hard to find info on it there.)
    Buy My Books
  3. I tried, didnt really find anything. the dvd writer I have is a olympus S-DVD-100.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Nero InfoTool is a easy program to use.
    http://ww2.nero.com/nero6/eng/Info_Tool.html
  5. DVDInfoPro is also likely to give you the info that you want.
  6. Member gadgetguy's Avatar
    From one of the first sites listed on Google...
    http://www.techdepot.com/product.asp...info=Tech#tabs
    Buy My Books
  1. Replies: 1
    Last Post: 26th May 2011, 10:55
  2. Who here knows their technical stuff inside and out???
    By suomalainen in forum DVD & Blu-ray Players
    Last Post: 12th Dec 2009, 22:39
  3. Suspicious Specs for DVD menu
    By steviespin in forum Authoring (DVD)
    Last Post: 25th Jan 2008, 05:06
  4. Software to view technical info of dvd video
    By cengoh in forum Software Playing
    Last Post: 28th Sep 2007, 03:59
  5. Why was 48khz needed for DVD specs?
    By yoda313 in forum Audio
    Last Post: 7th Jul 2007, 15:57
