Please clarify:
Am I under the ?mistaken? belief:
1. That in the near future true HDTV from Cable or Sat will only be broadcast over HDMI?
2. Connecting to any other output - besides HDMI - from a Cable or Sat HDTV reciever results in something other than HD signal.
Then:
Are most Cable and Sat providers currently enabling encryption on their popular HD broadcasts preventing HD capture to a HDD on your PC?
Nothing is "broadcast" over HDMI. HDMI is a digital format that many/most HDTVs will accept as an input through their HDMI connector. It could be that many cable/satellite boxes will have HDMI output. In this case, the cable/satellite box will take care of unencrypting the signal, and the boxes will still have analog progressive-scan component video outputs, which you can connect to your HDTV/monitor analog inputs. The signal from the HDMI connector will probably not be encrypted, either.
There are others on this forum who know more about this than I do, so I am prepared to be corrected.
Only if the Broadcast flag passes in Congress (for local DTV stations). Then cable operators would be forced into requiring a HDCP encryption capable connection (HDMI and some DVI) in order to pass a flagged program. Other outputs (IEEE-1394, DVI and analog component) would be forced to 720x480.Originally Posted by EAO
It hasn't passed yet. Fight the broadcast flag here.
http://www.eff.org/IP/Video/HDTV/
http://www.eff.org/IP/Video/HDTV/?f=broadcastflag.html
Other cable HDTV content may or may not be forced into HDCP encryption based on the agreement between the program producers and the cable company. Cable companies know they will have angry customers if they do this.
Note that the HD DVD players will require an active HDCP connection in order to play in HD formats.
Only for flagged content (see above).Originally Posted by EAO
Yes and no. Seems to vary by local cable systems but the capability to do this is built into the equipment. Here, all cable digital content is blocked on the IEEE-1394 digital connection.Originally Posted by EAO
Last April, the FCC specifically prohibited cable companies from encrypting local DTV (SD or HD) broadcasts but the local DTV station can encrypt if they desire.
For this reason, the IEEE-1394 (D-VHS MPeg2 TS) output on cable boxes is usually left unencrypted for the local DTV channels.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Computer to HDTV using HDMI
By rajtp in forum DVB / HDTVReplies: 6Last Post: 17th May 2011, 17:30 -
HDMI on an older HDTV- it works!
By Eyedoctor2 in forum DVB / HDTVReplies: 14Last Post: 12th May 2011, 03:52 -
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 13:50 -
Confused ~~ Capture FIOS HDTV??
By Ghost2099 in forum CapturingReplies: 7Last Post: 17th Sep 2010, 09:26 -
HDMI to Interlaced HDTV
By spysr in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Oct 2007, 12:13
Statistics
Newest guides
Latest tool updates
New media comments
