Okay, i messed with this before and gave up!!
Just tried again!!!![]()
If i want to upload a zip file for someone to DL in a thread, it's a small 50kb font,
How do i know where to link to it in my post![]()
I saw p_l testing it but![]()
Results 1 to 14 of 14
Originally a member since 2001, LONG LIVE TARAN's!!!
It's the same thing as uploading pictures except that you wrap it in http://[/url ] tags instead of [img ...atucksfile.zip blah blah blah.
Then make sure you have browsed and loaded your file below.
I know that much gheezOriginally Posted by Shadowmistress
adalogo.zip
Ahhh there it goes!! :P
Thanks!!
See, i thought i tried that before and it did not work, but i saw that when ever i uploaded it, it looked like it was in the guides section with the thread # in the URL so i was trying to link it that way with the [url][/url ]
I was trying to link it like this, adalogo.zip
Obviously i put the spaces there so it can be seen what i was doing.Originally a member since 2001, LONG LIVE TARAN's!!!
You never need to do that manually as the board will do it for you. The code you mention above works if you want to replace the actual filename with words instead. Like when the filename is noatuck.zip but you wish to display "my guide" in your post and have those words become a link.
In order to do that you type my guide or
my guide
I know all that other stuff, but like i said, i thought i tried it the "right" way before and it did not work so i was trying the other way without even trying the "right" way again for files 8)Originally a member since 2001, LONG LIVE TARAN's!!!
Here I was thinking that this was pretty self-explanatory:
If in doubt, Google it.
Allright, now that just confused me. :POriginally Posted by jimmalenko
EDIT: Ah, you sneak. I quoted it right when it showed just the code but you snuck in there and edited just as I hit quote.
Ok, I'm not confused anymore. 8)
Yeah .... I'm too quick for my own good sometimes
I'll just leave that one alone....
What .... AGAIN ?Originally Posted by Shadowmistress
j/k.
Deja vu sucks, don't it?
Not *touching* thatOriginally Posted by Shadowmistress
OK ... I'm done
That was quick.Originally Posted by jimmalenko
:P
Well son of a bitch!!!!!!!!!!!!!!!!!!!!!!Originally Posted by jimmalenko
Linking Test
By olyteddy in forum TestReplies: 1Last Post: 13th Jun 2010, 17:33 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum CapturingReplies: 1Last Post: 23rd Apr 2010, 10:40
