Hi all,
I have a newbie question here. I ripped my DVDs using SmartRipper. Now, when I play them back on PowerDVD (in File Mode), how do I display the subtitles? PowerDVD doesn't seem to want to open the .IFO file.
Is there any other DVD player software that would play the VOB files and dispay the subtitles?
Thanks for your help.
tondinh
If you have Power DVD Version 3 It will not play the files as a normal dvd. Power DVD 4 however will. Power DVD 3 would only play the .vobs in order of entry, Power DVD 4 will open the .ifo and play the movie from your harddisk as if it were on the DVD. Make sure you get the Power DVD patch that has been released for version 4. The patch seems to clear up some of the hesitation in playing a DVD from the harddisk.
damnim
damnim, thanks. I just got PowerDVD 4.0. However, when I clicked on "Open DVD File on Hard Disk Drive" and chose the .IFO file, PowerDVD wouldn't play it. Do you know why?
Also, where did you find the patch. I couldn't find it on the official website.
Thanks again.
hey this also happens to me! And guess what, I've updated using the patch from the site but still no difference. I do the same procedure but nothing occur. anyone has a solution for this?
damnim,
u said we can play the DVD directly from the HD like it was from the DVD itself. But, when I do 'open dvd from harddisk' in powerdvd 4 and choose the IFO file it does nothing. PLZ HELP ME OUT
Originally Posted by d_nimrod
i HAVE THE SAME PROBLEM...
DID U GUYS HAVE ANY SUCCESS AT ALL WITH SOME OTHER SOLUTION???
Subtitle for mts playback in MPC-HC
By cheerful in forum Software PlayingReplies: 1Last Post: 24th Feb 2010, 08:35 -
Playback of DVBT .ts files with subtitle support
By cat in forum DVB / HDTVReplies: 8Last Post: 15th Nov 2009, 20:20 -
DVD playback not showing up on TV (s-video out in Clone view)
By kalii2 in forum Software PlayingReplies: 4Last Post: 29th Oct 2009, 14:17 -
What program to view subtitle files?
By andre477 in forum SubtitleReplies: 3Last Post: 2nd Nov 2008, 15:15 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01
