I am using JVC DVX-90 but can't capture date & time when using DV link capturing to computer, is there any DV cam can capture Date & Time while using DV link?
Hi Clarence Yu,
I'm not entirely clear on what you want to do, but I think that there are a number of tools in the "DV" section that might help.
Including... DVdate, DV Sub Maker and other similar ones in the same "DV" tools category.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Hi daamon,
Thanks for reply.
My question is :
When I capture DV tape to VHS recorder using RCA cable, the date & time of recording (on the right bottom corner one) can be captured together to the VHS tape. However, if I use I-Link to capture DV tape to PC, the date & time of the recording are missed. The reason I tried DV to PC by using I-Link because of much better video quality than VHS
Is all I-link connection can't support date & time capturing? Because, I even can't read the date & time shown when I playback the DV tape directly to TV using I-link (thru DVD recorder)?
Thanks for advice.
The date/time are 'captured' when you trasfered the recording to the pc. You are going to need to find some software to make a subtitle of the date/time. http://www.videohelp.com/tools?s=33#33
Capture from Video Cam to Computer with Time and Date Stamp
By Larrypi in forum CapturingReplies: 2Last Post: 14th Mar 2011, 09:05 -
Date & Time capture of DV using Enosoft DV Processor
By nharikrishna in forum CapturingReplies: 3Last Post: 17th Jan 2011, 16:07 -
Issue w/ DV AVIs & DV Date/Time Software
By jeremyofmany in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 28th Oct 2010, 13:00 -
Date & Time
By fzf5bl in forum MacReplies: 1Last Post: 8th Nov 2007, 02:48 -
Date & Time Captured by DV out of Video Camera
By Mazen in forum CapturingReplies: 17Last Post: 13th Oct 2007, 10:00
Statistics
Newest guides
Latest tool updates
New media comments
