VideoHelp.com Forum
    I'm looking to buy inkjet paper for use with my Epson R200 for printing slim DVD case inserts. I was curious what other people used and experiences with various stocks. I was looking at trying this stock:
    http://www.amazon.com/gp/product/B00...lance&n=172282
    I don't need a glossy finish, though I wouldn't be against trying glossy. I also don't want a stock that is too thick.
    Hammermill 28-pound paper, 8½x14
    Can you give a link of where to buy it? Why do you recommend this paper?
    I use "royal brites matte photo paper" from Sam's club. Dirt cheap (IIRC $10 for 200), looks very good. 8 1/2 x 11 is OK for slim cases. For normal ones, it runs short and 8 1/2 x 14" is better.
    I have found that "Premium HP Presentation Paper" 32 lb 150 sheet packs Matte finish gives a bright printout and is only about $12 at Office Depot or Stapples.
    I have been using for about 6 months and no complaints.
    I use undercoverXP to resize the cover to slim then print it on my R200 using Kirkland(Costco) glossy photopaper. 125 sheets for $18 cdn or so.
    I was using Likon Paper (10 sheets for a $1) but thought I'd try the Kirkland out this time around.
    For cutting I splurged and spent $2, 1 for a steel ruler and 1 for a X-acto style knife.
  7. Member terryj's Avatar
    I use the Meritline Glossy DVD Paper Inserts,
    and just go in a 1/4" on either side to fit the
    standard slims, 3/16" in either side for the Verbatim
    (sold at Sam Stores) slim cases.
    Reason I do this rather than buy the specially made slim insert paper,
    is that when I do season sets ( 4 disc, 6 discs) I only
    have to stock one insert paper, and can just trim
    when I have a single disc/2 disc set I need to do.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    That's exactly what I do too. I find it easier to just stock the regular size, and simply cut off a bit if I use a slim case.
  1. What's some good paper for DVD inserts?
    By slayerbizkit in forum Media
    Last Post: 21st May 2011, 09:01
  2. 50 pk slim DVD cases
    By zoobie in forum Media
    Last Post: 14th Feb 2010, 18:53
  3. DVD Covers - What Paper?
    By Nitro89 in forum Media
    Last Post: 15th Apr 2009, 18:02
  4. Best way to save/print DVD case inserts?
    By stantheman1976 in forum Newbie / General discussions
    Last Post: 11th Dec 2007, 13:33
