VideoHelp.com Forum
  1. something strange is happening. I'm not sure it's anything to do with ffmpegx but I can't figure it out so, thought I'd check in case someone knows about this.
    I was encoding a file to dvd. it failed and the error was that it couldn't locate or open the source file... something like that.
    I had about 10G of space on my internal drive (i was encoding to an external).
    i tried to encode again and I can't remember if it was before I tried again but my available disk space went down to around 150MB then it gave it back.
    After i tried to encode and it failed again, it showed i had no space available on my drive. I restarted but it didn't give back the space. I've totaled all the folders on my drive and it adds up to 50G on a 80G drive. so, whatever is taking up this space seems to be invisible??
    i ran disk warrior which didn't help and restarted many times.
    I also found something called cache out X which deletes the virtual memory files but that didn't help.
    does anyone know what this could be??
  2. I didn't observe anything like that, perhaps you may use OmniDiskSweeper to check which is the file taking that room.
  1. ffmpegx occasionally creates 0kb files instead of encoding properly
    By digitalgeist in forum ffmpegX bugs and suggestions
    Last Post: 27th Dec 2009, 19:22
  2. "The Waveform Cache Files Folder does not have read/write access.
    By fionawhitty in forum Newbie / General discussions
    Last Post: 16th Oct 2009, 19:25
  3. Replies: 4
    Last Post: 14th May 2009, 19:36
  4. Seagate Disk Wizard files invisible to Windows
    By bevills1 in forum Computer
    Last Post: 4th Apr 2009, 11:08
  5. ConvertX mystery: invisible files ??
    By Seeker47 in forum Video Conversion
    Last Post: 22nd Sep 2008, 00:59
