I recently upgraded to a Sony dru-810 a. I use verbatim dl dvd+r discs. When I go to backup my disc and try to rip the contents off of it or make sure the disc is good, I get;
Cannot copy vts 01 3 data error (cyclic redundancy check)
my other dvd-rs work fine
Should I back this up as data dvd+r?
I backed it up as video dvd+r
I have used those discs for countless data and video backups with my Sony 810UL burner. Shouldn't matter what you put on the disc, whether its data, audio, or video. Haven't had a problem with that media. Does this happen all the time?
No problems with over 40 +dl discs used so far.
What We Do In Life, Echoes In Eternity....
I had a problem with my first few Verbatim DLs, but I believe that was more firmware related than disc related. I recently upgraded the firmware of my Plextor 740A to v1.02, and that seemed to fix many problems, including burning cleanly to DL discs (Verbatim)
Question about Verbatim dvd+r dl Discs I just bought
By frieday in forum MediaReplies: 2Last Post: 10th Oct 2009, 17:43 -
Which is a better option for dl discs - memorex or verbatim?
By yoda313 in forum MediaReplies: 7Last Post: 4th Jul 2009, 13:24 -
Verbatim +R DL discs...
By Krispy Kritter in forum MediaReplies: 12Last Post: 19th Jun 2009, 10:35 -
The first and/or last few discs of Verbatim 100 DVD spindles...worse?
By Bix in forum MediaReplies: 5Last Post: 18th Sep 2008, 10:40 -
Are Verbatim's 'Made in Taiwan' discs...
By dvdashot in forum MediaReplies: 2Last Post: 8th Aug 2007, 13:55
Statistics
Newest guides
Latest tool updates
New media comments
