VideoHelp.com Forum
  1. Hey guys,
    Ive got a bit of a problem (not really sure if this is the right forum).
    I'm trying to capture from my Sky + box. I am using the s-video out and using an s-video to composite converter (I've got a long composite cable). The problem is its in black and white. There is no problem with the my PC because I tried viewing it on my TV, its still in black and white.
    So I was thinking of buying an s-video cable instead. Will this be a waste of money though? Is it likely to make a difference. The problem either has to be with the s-video to composite converter or my Sky + box (I know the cable works).
    What do you guys think?
    Also what would you guys recommend as the best free capture software?
    Thanks.
  2. Member roglopes's Avatar
    No answers ?
  3. Member edDV's Avatar
    So how are you making the connection from Svideo (4pins) to composite (2pins) ?
    At the connector, S-Video = luminace and ground + chrominance and differenent ground. or 4 pins.
    http://www.kiva.org/about
  1. capturing from sky+ box to pc
    By supercoop in forum Capturing
    Last Post: 7th Jan 2012, 20:11
  2. Sky+ HD to PC
    By BIGD22 in forum DVB / HDTV
    Last Post: 27th Sep 2011, 13:59
  3. Problem capturing sky digibox recordings
    By scamperoo in forum Capturing
    Last Post: 19th Oct 2009, 09:32
  4. Sky + And/Or Sky HD Recording To Pc With DAZZLE
    By akenny01 in forum Capturing
    Last Post: 7th Mar 2008, 18:02
  5. Sky+ to PC
    By pjvw in forum Capturing
    Last Post: 13th Sep 2007, 12:00
