i posted that i used my ati card to download a vhs tape. the file size ended up to be 4.7 gb. i read the reply and loaded a calculator. all it says on the tape is 118 minutes. how can i determine what to put in the calulator ? if i read it right that if i lower the bitrate i should get a smaller file.
thanks
gregt
Changing the bitrate will vary according to which software you are using to do the captures.
There is some information here: http://www.divx-digest.com/articles/...h.html#capture
and here: http://www.digitalfaq.com/dvdguides/...eg/atimpeg.htmGoogle is your Friend
what type of ati card do you have? and why is this not being continued in the original post?
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 00:43 -
reencode x264 to lower bitrate
By reb0rn in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 00:54 -
Bitrate always comes out lower?
By MrMors in forum Video ConversionReplies: 6Last Post: 1st Jun 2007, 07:37
Statistics
Newest guides
Latest tool updates
New media comments
