VideoHelp.com Forum
Results 1 to 9 of 9
  1. Member Mr anderson's Avatar
    hi, i cant seem to find a Realtek RTL8100B driver for xp? does anyone know where i can download one?
  2. DVD Ninja budz's Avatar
  3. Member Dv8ted2's Avatar
    You could also probably get it from driverguide.com
    Believing yourself to be secure only takes one cracker to dispel your belief.
  4. Member Mr anderson's Avatar
    tried that one dont work? its for a emachines 820, someone formatted the damm thing & lost the drivers? look on driverguide.com aswell no good there.
  5. Member Mr anderson's Avatar
    is there any software out there, that can scan a system and tell you what drivers the hardware needs?
  6. DVD Ninja budz's Avatar
    what operating system are you using? XP should have the drivers. have you checked the BIOS to make sure the lan is ENABLED.
    you should be able to go through device manager to see which hardware needs drivers. didn't the emachines pc come with a recovery disc?
  7. Member Mr anderson's Avatar
    the emachines is a friends pc, the disk they cant find? they're using xp, just cant seem to find the damm driver
  8. DVD Ninja budz's Avatar
    Then do a live chat with emachines tech support to get the correct driver. I had to do that with a compaq computer which was frustrating but I got all the drivers for my cousins pc. All my cousin had was the xp home cd but not the drivers cd.
  9. Member Mr anderson's Avatar
    ok, there's some software out there done by some german company almost the same to cpuz, that will look for the drivers for you, but i dont knw the name?
  1. Realtek HD has no Stereo Mix?
    By EwanG in forum Audio
    Last Post: 4th Sep 2010, 08:53
  2. No stereomix after installed Realtek drivers!
    By LoveMyslf in forum Computer
    Last Post: 6th May 2009, 15:18
  3. Realtek audio card front headphone socket
    By didikai in forum Computer
    Last Post: 19th May 2008, 09:49
  4. Configuring microphone w/ Realtek HD Audio
    By Sean O'Scare in forum Audio
    Last Post: 24th Feb 2008, 07:05
  5. Realtek Audio Problems!
    By =CrAzYG33K= in forum Audio
    Last Post: 8th Jun 2007, 06:56
