i have this divx dvd player, and am wanting to know if anyone here knows EXACTLY the correct format/settings the video for XviD has to be for the player to play it correctly
xvid is the only problem i have with this player... the audio is out of sync with video , sometimes no sound at all... and the worst is sometimes the video is distorted in all diff colors but sound plays
if anyone has any info or a guide that can help me to convert xvid or to make the xvid play on this player WITHOUT any problems please respond!
Results 1 to 9 of 9
Thread: Philips DVP642 DivX Player
----> adamf9898 ---->
Required reading for any Philips 642 owner.
http://www.jarnot.com/twiki/bin/view...LisaBsAVIGuide
wow, thanks for this info , i found my solution from that page,... it was
QPel cannot be removed from an AVI. If your player doesn't play QPel, then you will have to re-encode the AVI
i hate to do it but its my only choice if i want a good playback
thanks again for your help
U know you can push the system menu 2 times & presto, your dvd picture should play right?
Left column, dvd players, search for yours.
That only works for the pixelated/funky color display problem. The 642 does not play QPEL...the file will not even load.Originally Posted by handyguyGoogle is your Friend
that didnt work for me either, i will just have to re encode ALL xvid videos to divx... and i use dr divx
i am not gonna mess around with any xvid videos anymore ... just encode them to divx----> adamf9898 ---->
Nonsense. Only some Xvid videos contain QPEL. If you're making your own Xvid AVI files simply turn off the QPEL and GMC options.Originally Posted by adamf9898
no i dont make my videos using xvid , i always try to use divx
only xvid that i have is what i got from others----> adamf9898 ---->
My point was that both codecs can produce files with or without QPEL and GMC. If you don't want the features don't enable them when encoding. Most Xvid files I've downloaded do not use GMC.Originally Posted by adamf9898
In my opinion Xvid produces slightly better image quality (for a given file size) than Divx. Divx 6.1 does have a speed advantage if you use the faster settings ("Fastest" and "High Performance").
Need another Philips USB Divx Player
By s-toon in forum DVD & Blu-ray PlayersReplies: 38Last Post: 21st Apr 2011, 21:12 -
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 14:39 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 14:06 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43
