right my m8 has a hdd which he has had for a long time (from new),he formated it installed xp pro on it loads of times(he says). his pc started shutting down at the same time every day ,so he did the usuall thing virus check ,adware ect , nothing showed up (clean),so he decided to formate the thing and start again .
put now the hdd is asking for a admin password and not letting him formate it ,he said he has never put admin password in at all or any password in xp pro apart from places like this site,and the cannot insatall any software or drivers any more plus he has lost the broadband and dailup .
is there a way round the admin password to get it formated so he can start again or has he lost the hdd with out the password ,
or can you put it on another pc to formate it has a slave drive,
or can he put it on another pc to scan it for viruses to clean it right with a better antiveirus ,adawere /malware scanner to fix it if possible (me think not posible )
he uses AVG free and Mcafee for viruses , adawre /malwere do not now.
one more thing will his over hdd's be the same need the admin password to formate them
Thread: admin password in xp
put it in another pc and format it.
or use bootable cd to boot then format it.
if he has the time for formatting his hd then it is better to format it than to scan it any antivirus program.hacking the Net using typewriter :D
He can just take ownership of the contents using his existing admin account. From there he can do what he likes. Some reading to get him started
http://support.microsoft.com/default...308421&sd=tech
thx will try them (he will)
If he is formatting his drive completely, he wouldn't need an admin password.
Greetings,
I suppsoe you using Active@ password changer utility to reset forgotten password. This is a small yet powerful utility that can really reset lost password. That did helped me before so I think you will also find it useful.
http://www.password-changer.com/
Advice needed on adding Windows Password to Admin
By ahhaa in forum ComputerReplies: 2Last Post: 20th Jul 2010, 00:26 -
Need Admin Help!
By Husk3r in forum FeedbackReplies: 4Last Post: 17th Feb 2009, 15:59 -
Help with pc admin properties
By SIRCOOKS in forum ComputerReplies: 7Last Post: 29th May 2008, 17:54 -
Remote PC Admin Control?
By Xenogear900 in forum ComputerReplies: 6Last Post: 11th Oct 2007, 08:35 -
Installing on a NON-Admin account?
By mamefan in forum ffmpegX general discussionReplies: 2Last Post: 27th Jun 2007, 11:47
