  1. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    when I right-click an item in Windows, I've got an extra "Open With..." and I'd really like to get rid of the WinZip option.
    Is this a registry tweak, or can somebody tell me the Windows (2K Pro) trick to change this?
    TIA!!
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  2. Member isogonic's Avatar
    Jan 2003
    @localhost
    cant you make that change from winzip itself, under preferences or options or configuration.
  3. it's in the shell file when you install winzip
    You can go here in the registry to change it:
    HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\wi nzip
    Just delete that file and it will be gone.
    Safest way:
    Unistall winzip
    reboot
    Reinstall winzip and when it ask to "Add to shell extensions" say NO
  4. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    yeh, I got rid of the WnZip deal, but what about that extra "Open with"??
  5. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    edit
