Hi, I have a DVD Fight Club and want to back it up onto a Verbatim DL disc. The original disc is almost 8 GB and the movie is around 6.7 GB.
I want to put ONLY the movie on the dual layer disc. My question is DVD Shrink has the option to remove or leave the layer break. What's the best way to place a movie ONLY on a Dual Layer disc? Can I decide where to place it or is it done automatically?
I'd like to have it change at the end of a chapter instead of during a scene.
For best results you should use DVD Decrypter and do a simple ISO->Read, ISO-Write. This will remove all the restrictions, so you can skip the intros and menus etc., but keep the layer break where it is. It will all fit on a DL disc anyway.
There are erstrictions to the placement of the layer break on (re)writable disks which may restrict you from placing it where you please.
If you must strip it down to movie only, I would suggest you then use a DL aware authoring program to create new chapters and to place the layer break where you think it works best.
Being still mostly untutored in this, I have long wondered about the purpose of the "Remove Layer Break" option in Shrink, as well as the pros & cons. (I frequently left that option checked, without a bad result, so far as I could see.) Presumably this was only intended for use in having the movie go onto DVD5 ? If you needed a DL for length reasons, this would probably be a bad idea -- right ?Originally Posted by guns1inger
Once you strip down the structure to movie only, the original layer break becomes wortless. Because of the way writeable DL DVDs are burned, a whole new layer break piont must be calculated and created.
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Break on dual layer disk
By audax in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2009, 21:34 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 18:41 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
Statistics
Newest guides
Latest tool updates
New media comments
