VideoHelp.com Forum
  1. Member jeffshead's Avatar
    I have a DVD that has 6 episodes and a basic menu. When I put the DVD in a stand alone or PC, nothing happens until I push play. Then the 1st episode plays, then each episode continues to play till the end. The menu never pops up unless I hit the menu button on the remote. The menu is very basic with a pic for each episode and a name. You are able to click on a pic and it will play that episode. I was told the disc was authored using professional stand alone equipment. Not a PC.
    ??? What I want to do is make it so the menu auto plays when the DVD is inserted. Then the user can select which episode to play. When it finishes playing, I want the next episode to play without going back to the menu.
    I have searched and searched and tried different things from posts that were related to similar issues, but nothing has worked.
    ??? Is there a simple way to reauthor the DVD without reencoding?
    I tried using Infoedit, but I don’t know what the h*ll I’m doing. I compared info with other DVD's and found there is no PGC Command Table or Pre Command's such as JumpTT in the VIDEO_TS.IFO
    Here is a pic which shows the list of files on the DVD:
    ??? Will one of you pros tell me what to look for and change in Infoedit?
    I will be most gratefull!!
    Use PGCEdit and put your own Jump command in to go to either the menu, or a title of your choice.
    Here are a couple of guides to take you through it
    http://www.videohelp.com/guides.php?guideid=806#806
    http://www.videohelp.com/guides.php?guideid=703#703
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member jeffshead's Avatar
    Thanks guns1inger. I will give it a try and let you know!
  4. Member jeffshead's Avatar
    Yahoo!!
    I was able to use PgcEdit, ImgBurn, and ImgTool Classic to make all my DVD's auto play the title menu when inserted. No coasters!
    Thanks again guns1inger for the links. I was so happy I sent donations to the authors.
  1. How make auto-play jpg-foto-DVD for standalone DVDplayer?
    By onidarbe in forum DVD & Blu-ray Players
    Last Post: 20th Oct 2009, 03:20
  2. Replies: 7
    Last Post: 3rd Aug 2009, 14:42
  3. Replies: 3
    Last Post: 2nd Aug 2009, 05:13
  4. Replies: 22
    Last Post: 16th Mar 2008, 11:06
  5. Will DIVX with Menu Play on Standalone DVD-Divx player?
    By psxiso in forum Video Conversion
    Last Post: 4th Oct 2007, 10:24
