Hi,
I am converting the following file to a svcd
Video : XVID 624x352 12bpp 23.976
fps 1024.6kbps (125.1 kbyte/s)
audiocodec: framecopy (format=55 chans=2 rate48000 bits=0 B/s=13524 sample-0)
I open the source file and choose the "save as" making sure there are no spaces or unusual characters. I choose the SVCD mpeg2enc to encode the files as i need to add subtittles. I choose "Decode with mplayer" I have checked the file plays ok and when i use the preview everything looks ok. The encoding goes fine until the very end when it says failed in red. Below is a copy of the information. The only error i can see is at the bottom which is
ERROR: could not stat() file `/Volumes/Stuff/Movies/Lost/Lost13/lost113:': No such file or directory
I can then burn the files using the .toc in missing media burner as I couldn`t figure out if it was possible using ffmpegX, it all seams to work fine but I would like to find out what the error means so that I can rectify it as the mentioned directory does exist. Your help is much appreciated.
Thanks in advance,
Mal.
Encoding started on Mon Dec 26 16:36:00 JST 2005
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
/Volumes/Stuff/Movies/Lost/Lost13/lost113/
-f 5 -b 2500 -q 6 -B 260 -V 230 -a 2
-F 1
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/Mal/.mplayer/input.conf'
Can't open input config file /Users/Mal/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
get_path('LostS01x03.avi.conf') -> '/Users/Mal/.mplayer/LostS01x03.avi.conf'
tS01x03.avi.
get_path('sub/') -> '/Users/Mal/.mplayer/sub/'
[file] File size is 365580288 bytes
STREAM: [file] /Volumes/Stuff/Movies/LostSeason1/LostS01x03.avi
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
AVI file format detected.
list_end=0x2292
======= AVI Header =======
us/frame: 41708 (fps=23.976)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
frames total: 61210 initial: 0
streams: 2
Suggested BufferSize: 0
Size: 624 x 352
list_end=0x10F4
==> Found video stream: 0
====== STREAM Header =====
Type: sdiv FCC: divx (64697678)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 0
Rate: 24000/1001 = 23.976
Start: 0 Len: 61210
Suggested BufferSize: 80610
Quality 10000
Sample size: 0
Found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 624
biHeight 352
biPlanes 1
biBitCount 12
biCompression 1145656920='DIVX'
biSizeImage 1317888
Regenerating keyframe table for MPEG4 video
list_end=0x2186
==> Found audio stream: 1
Type: sdua FCC: (0)
Flags: 0
InitialFrames: 1
Rate: 48000/1152 = 41.667
Start: 0 Len: 106372
Suggested BufferSize: 672
Quality -1
Sample size: 0
Found 'wf', 30 bytes of 18
======= WAVE Format =======
Format Tag: 85 (0x55)
Channels: 2
Samplerate: 48000
avg byte/sec: 13524
Block align: 1152
bits/sample: 0
cbSize: 12
mp3.wID=256
mp3.fdwFlags=0x2000000
mp3.nBlockSize=17409
mp3.nFramesPerBlock=256
mp3.nCodecDelay=0
list_end=0x2292
AVI: dmlh found (size=248) (total_frames=61210)
list_end=0x22B6
hdr=Software size=15
Software : Nandub v1.0rc2
list_end=0x15A161CA
Found movie at 0x280C - 0x15A161CA
Reading INDEX block, 167582 chunks for 61210 frames (fpos=0x0)
AVI index offset: 0x2808 (movi=0x280C idx0=0x4 idx1=0x18C)
Auto-selected AVI audio ID = 1
Auto-selected AVI video ID = 0
AVI: Searching for audio stream (id:1)
AVI video size=326989014 (61210) audio size=34527312 (106372)
VIDEO: [XVID] 624x352 12bpp 23.976 fps 1024.6 kbps (125.1 kbyte/s)
[V] filefmt:3 fourcc:0x44495658 size:624x352 fps:23.98 ftime:=0.0417
Clip info:
Software: Nandub v1.0rc2
SUB: Detected subtitle file format: subviewer
SUB: opened iconv descriptor.
SUB: closed iconv descriptor.
SUB: Read 483 subtitles.
SUB: added subtitle file (1): /Volumes/Stuff/Movies/Lostsubs/Lost1x03.srt
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
dec_audio: Allocating 4608 + 65536 = 70144 bytes for output buffer.
mp3lib: using generic C decore!
MP3lib: init layer2&3 finished, tables done
MPEG 1.0, Layer III, 48000 Hz 128 kbit Joint-Stereo, BPF: 384
Channels: 2, copyright: No, original: Yes, CRC: No, emphasis: 0
AUDIO: 48000 Hz, 2 ch, s16be, 128.0 kbit/8.33% (ratio: 16000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
Using (default) progressive frame mode.============================================= =============================
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
INFO: [yuvscaler] SVCD output format requested in NTSC norm
/2ch/s16be -> 0Hz/0ch/s8...
[libaf] Adding filter dummy
[dummy] Was reinitialized: 48000Hz/2ch/s16be
[AO PCM] File: audiodump.wav (WAVE)
PCM: Samplerate: 48000Hz Channels: Stereo Format s16le
[AO PCM] Info: Faster dumping is achieved with -vc null -vo null
PCM: Info: to write WAVE files use -ao pcm:waveheader (default).
AO: [pcm] 48000Hz 2ch s16le (2 bytes per sample)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
INFO: [yuvscaler] input: frame size: 624x352 pixels (329472 bytes)
INFO: [yuvscaler] input: frame rate: 2997003/125000 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 624x352, take 624x352+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 480x360, 480x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
ilter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16le...
[libaf] Adding filter format
[format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
[format] Accelerated endianess conversion only
Starting playback...
] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 60 above and 60 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 13 to 10
INFO: [yuvscaler] and is 44 to 45 for height
ating memory in module format, old len = 0, new len = 65540
[ffmpeg] aspect_ratio: 1.772727
VDec: vo config request - 624 x 352 (preferred colorspace: Planar YV12)
Trying filter chain: vo
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.77:1 - prescaling to correct movie aspect.
VO Config (624x352->624x352,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 624x352 => 624x352 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [mpeg2enc] Selecting SVCD output profile
ocating (slices) mp_image_t, 624x352x12bpp YUV planar, 329472 bytes
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Volumes/Stuff/Movies/Lost/Lost13/lost113.mpv
INFO: [mpeg2enc] Horizontal size: 480 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 2500 KBit/s
INFO: [mpeg2enc] Quality factor: 6 (Quantisation = 6) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
Unicode font: 242 glyphs.
default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [yuvscaler] output: frame size: 480x480 pixels (345600 bytes)
INFO: [yuvscaler] output: frame rate: 2997003/125000 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
XXX initial v_pts=0.000 a_pos=7440 (0.550)
*** [vo] Allocating (slices) mp_image_t, 624x352x12bpp YUV planar, 329472 bytes
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
ber 24835
uant=6.00 total act=3262723.2
0
quant=6.00 total act=3263699.4
ame number 24845
=3264380.1
1.2% 9124 0
otal act=3264905.0
total act=3265511.9
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
Uninit audio filters...
[libaf] Removing filter dummy
[libaf] Removing filter format
uninit audio: mp3lib
uninit video: ffmpeg
Exiting... (End of file)
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 61211!
INFO: [mpeg2enc] Guesstimated final muxed size = 638617656
wait, encoding to mp2 audio with mp2enc...
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 490143744 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/Stuff/Movies/Lost/Lost13/lost113.mpa"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/Stuff/Movies/Lost/Lost13/lost113.mpv looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/Stuff/Movies/Lost/Lost13/lost113.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 4 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Stuff/Movies/Lost/Lost13/lost113.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 23.976 frames/sec
INFO: [mplex] Bit rate : 2500000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Stuff/Movies/Lost/Lost13/lost113.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2771544
INFO: [mplex] target data-rate specified : 2788800
INFO: [mplex] Setting specified specified data rate: 2788800
INFO: [mplex] Run-in Sectors = 78 Video delay = 46800 Audio delay = 50553
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 61210
INFO: [mplex] STREAM e0 completed @ frame 61210.
INFO: [mplex] STREAM c0 completed @ frame 97724.
INFO: [mplex] Multiplex completion at SCR=229791600.
INFO: [mplex] Video e0: buf= 216527 frame=061210 sector=00243693
INFO: [mplex] Audio c0: buf= 439 frame=097724 sector=00031132
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 555644871 bytes
INFO: [mplex] Sequence headers: 4177
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 61210
INFO: [mplex] No. Groups : 4177
INFO: [mplex] No. I Frames : 4177 avg. size 17770 bytes
INFO: [mplex] No. P Frames : 16344 avg. size 10716 bytes
INFO: [mplex] No. B Frames : 40690 avg. size 7526 bytes
INFO: [mplex] Average bit-rate : 1740800 bits/sec
INFO: [mplex] Peak bit-rate : 2543600 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 181076
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 71478857 bytes.
INFO: [mplex] Syncwords : 97725
INFO: [mplex] Frames : 55843 padded
INFO: [mplex] Frames : 41882 unpadded
INFO: [mplex] BUFFERING min 16 Buf max 746
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `/Volumes/Stuff/Movies/Lost/Lost13/lost113-1.mpg.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `/Volumes/Stuff/Movies/Lost/Lost13/lost113:.xml'
**ERROR: could not stat() file `/Volumes/Stuff/Movies/Lost/Lost13/lost113:': No such file or directory
++ WARN:
++ WARN:
Encoding completed on Mon Dec 26 18:53:28 JST 2005
Results 1 to 9 of 9
Which is the name of your source file? Does it contain any special character?
I can reproduce this error with very plain filenames.
It may have to do with the filename creation of the xml file, which contains illegal character ":" before the dot:
Code:++ WARN: (Super) VideoCD xml description created successfully as `/Volumes/Stuff/Movies/Lost/Lost13/lost113:.xml'
Cheers for the reply,
the source file is called LostS01x03.avi
and the path is /Volumes/Stuff/Movies/LostSeason1
thanks in advance,
Mal.
Okay, and which was the name you used for your destination file?
the destination file was called lost113
with the path /Volumes/Stuff/Movies/Lost/Lost13
cheers
Anyone got any ideas?
Cheers, mal.
Did you kept the mpg files? You may use the author tool on them to reauthor to SVCD images.
Yes, I have them but used the .img file to burn the svcd.
Cheers for the info.
Mal.
Problem with Converting Directory of Files with Popcorn AudioConverter
By Petes457 in forum AudioReplies: 2Last Post: 28th Jun 2011, 15:25 -
what is the ANY! folder/directory?
By stackner in forum Blu-ray RippingReplies: 0Last Post: 27th Feb 2010, 16:07 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 07:35 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41
