VideoHelp.com Forum
Results 1 to 16 of 16
    I feel I am missing something obvious, but I can't figure out how to rip a single episode off a multiple episode disc, so that a 4 episode DVD, for instance, can be ripped into 4 separate files, one per episode. Is there a guide that addresses this? If so, where can I find it?
    "Only an idiot fights a war on two fronts. Only the heir to the throne of the kingdom of idiots fights a war on twelve."
    --Londo Mollari, B5
  2. Hi-
    It may partly depend on what you plan to do with the episodes, but one way is to set up DVD Decrypter to decrypt in IFO Mode (Mode->IFO, up at the top), set up a folder for each episode, and check the various VTS's for the various episodes. By default it's going to choose the longest one, and not necessarily the first one.
    I am trying that now, but still a little confused. The naming of the vobs is what is tripping me up, I think.
    For example, on the disc I am working with just to figure out the system, I have three VTS files:
    VTS_01
    VTS_02
    VTS_03
    And under each file, there are five smaller files. I am assuming the actual episodes are in these files. They are (in VTS_01):
    PGC 1 (00:43:50)
    PGC 2 (00:43:50)
    PGC 3 (00:43:51)
    PGC 4 (00:43:47)
    PGC 5 (02:55:20)
    Now, it would seem to me that PGCs 1-4 are the actual episodes, as the time stamp seems to be about right for an hour-long TV episode when the commercials are edited out. But then, what is the nearly 3-hour long PGC 5? There are no bonus features on the disc in question. What about the PGCs under VTS_02 and VTS_03? Those are all about 30 seconds long, I think. Are those just menu files?
    I'm just not sure how to tell what's what when looking at the file structure of the DVD. I swear I've seen one where everything was under VTS_01.
    --Londo Mollari, B5
  4. Hi-
    OK, instead of having each episode in its own VTS, they're in different PGCs of the same VTS. That's not unusual. The 5th PGC is the sum total of all the episodes together. Perhaps there's an option in the menu to "Play All" or something like that. That doesn't mean (unless they're idiots) that they stored all the episodes separately, and then also stored them again all joined together on the DVD. They're stored once, and that 5th PGC references each of the other 4 in turn. What you want to do is to decrypt each of PGCs 1-4 to separate folders, and ignore the 5th one.
    The other 2 VTSs are most likely logos of some sort. You could also decrypt them if you're curious and play them to see. They're not menus, as you don't see them when decrypting in IFO Mode.
    Manono:
    Thank you very much. It seems safe to assume that usually the episodes will be in sequential order, as there appears to be no way to check them until after the rip is done, or at least that's the way I'm proceding.
    It's true that the disc in question does have a "play all" option, so I think your idea about what the fifth part was is correct.
    One last question: the last disc of the set had some bonus features on it, at least some of which were in VTS_02 (the episodes were in VTS_03 on this particular disc for no reason I can grasp at this particular moment) and again, the problem of figuring out which 3 or 5 minute segment was which was an issue, but what's more, none of the bonus features I ripped had an audio track. Do you have any idea why that would be?
    Thank you for your help.
    --Londo Mollari, B5
  6. I've done only a few TV series DVDs, but quite a few anime series DVDs, and they were all in the right order. Shouldn't be too hard for you to make sure by comparing them with the order when playing the DVD.
    You're welcome.
    With multi-episodes sometimes I think it is helpful to use Shrink or Re-code in re-author mode to isolate the individual episodes. If you set the quality to 100 or no recompression all you're doing is copying, and it eliminates some potential prob. with subs & audio.
  8. Hi-
    ...none of the bonus features I ripped had an audio track. Do you have any idea why that would be?
    Sounds like your series DVD is a little light in the extras. There are several kinds of extras that may not have audio. Cast biographies and filmographies, and image galleries often don't have audio. There may also be other kinds of text screen extras without audio.
    The extras definitely were supposed to have audio--some of them were deleted scenes, and there was a blooper reel. For some reason, ripping them the way I ripped the episode just didn't get the audio.
    Actually, a bit discouraged now, as ripping, converting to XviD using autoGK and playing on my computer worked fine, but when I tried to play the file on my Philips 642, the color was weird--it was all multicolored verticle streaks. Still trying to hunt down the source of that particular difficulty, as both the DivX my husband made and other XviDs I have downloaded work fine on the Philips.
    --Londo Mollari, B5
  10. Hi-
    Hehe, you didn't install it with the ESS Option enabled. To put it reasonably simply, the matrices used by default in AutoGK aren't supported by ESS chipset based players such as the Philips DVP-642. In the Software Requirements and Installation section of the tutorial included with AutoGK, it says:
    ESS-based standalones. MPEG4 players with ESS chipsets don't work with the matrices that AutoGK uses with the XviD Codec (you don't have to understand what a matrix is, just follow the instructions). Please choose this option if you have such player. Perhaps the problem will be fixed with a firmware upgrade, and perhaps not. But you won't be losing anything, or getting a movie inferior in any way by choosing that option. If you have such a standalone player, and your XviD videos play with corruption and/or smearing, try this setting. For both XviD and DivX codecs this option also enables Home Theatre profile which is a part of DivX certification for hardware devices and which enables control over VBV buffer. Most standalones have issues with high bitrate spikes that cause internal memory of the player to be full and do not accept more data for a short period of time. This causes pauses, skips and and shuttering. Both DivX and XviD support intelligent control of output buffer overflows so that this problem can be eliminated. Make sure to turn this option on if you experiencing such symptoms during playback on your standalone. Note that its not the only possible reason for having pauses and skips - users reported that by burning movies onto DVDRs instead of CDRs playback can be dramatically improved. Also quality of DVD reader in standalone players varies a lot and cheap reader can be a reason behind your problems as well (check out Doom9's hardware forum for related discussions)
    http://www.autogk.me.uk/modules.php?name=TutorialEN
    You can either reinstall AutoGK, or you can access the Hidden Options (CTRL-F9) and check the "Standalone Compatibility" box. It'll probably be better in the long run to reinstall, because sure as heck you'll forget to do it again sometime and have the same problem.
    As for the deleted scenes with no audio, not real sure. If you put the DVD back into the DVD-ROM, open DVD Decrypter and highlight the deleted scenes and then hit the Stream Processing Tab at the top right, it'll tell you what kind of audio is in there. There's a chance that if the audio is AC3 (open the completed AVI in GSpot to find out), the fix could be as simple as installing the AC3Filter.
    Thanks again, Manono. I hadn't gotten that far along when I set it up, I was just trying to get a feel for what process would work for me. Glad to know it wasn't some obscure, impossible to diagnose problem but rather my own stupidity at work.
    The audio is in AC3, and I do have the AC3filter installed, but still no joy on the bonus features for some reason (maybe the audio is there, but just isn't being played when I test the ripped vob in PowerDVD, but that isn't the case with the episode vobs, and I don't want to spend the time encoding only to find out it isn't there.)
    --Londo Mollari, B5
  12. OK, lets try and get you some audio. You have the deleted scenes in their own folder, with a vob and an IFO, right? And when you play a vob (not the DVD, but one of the decrypted vobs), do you get audio? I'll assume the answer is yes. If so, then we know the audio is in the original decrypted Vob. So why didn't it make it into the AutoGK created AVI? Did you keep the log files? It creates logs at each step of the way. Something in the logs should give you a clue about what happened. Perhaps mistakenly you chose not to include the audio (not likely though). Perhaps for some reason AutoGK didn't find any audio. But all is not lost, even if you can't pinpoint the reason for the mysterious loss of the audio.
    Edit: I reread what you said and you say there's no sound when playing the decrypted Vob. You didn't do anything in the Stream Processing Tab of DVD Decrypter, did you? You might decrypt it again and see if there's audio this time.
    Open the Vob for the deleted scene in DGIndex. Go File->Save Project. With any luck you'll get some sort of audio, AC3 most likely. If it's AC3 you want, then mux (multiplex=add it in) it into the AVI using VDubMod. If you want MP3, then use something like BeSweet (it has a preset for MP3 for AVI) or HeadAC3he, and then mux it into the AVI using VDubMod. If DGIndex produces audio for you, but you don't know what to do next, then come back and I or someone else can help. Either that or look around the Guides portion of this site for a guide. Good luck.
    No. When I load the decrypted vob into PowerDVD, there is no audio.
    I haven't gotten that far with the bonus feature material, because if the audio isn't in the decrypted vob, I have to assume it won't be in the resulting encoded AVI. Obviously I am missing something in the ripping process, but I don't know what, I am doing the exact same thing as I am doing when I am using DVDdecrypter on the episode files, and those have audio.
    Like I said, I haven't gotten the the point of trying to encode the bonus material with AutoGK because I have not yet gotten a vob with sound in it to encode. This is pretty obviously a ripping issue, not an encoding one. But, again, it doesn't seem to make sense that the audio is there with the episode, and not there with the bonus material, when I am doing the exact same process with absolutely no alterations for both.
    I didn't alter anything from the settings I used to decrypt the episode files.
    I will try that, providing there is any audio there for DGindex to save.
    Again, thank you for your time and help and advice, it is greatly appreciated.
    Edit: all right, I successfully saved and .ac3 from DGIndex and converted it to .mp3 and played it, so YAY there is sound in there somewhere. Don't know why it wasn't playing when I tried to watch the decrypted vob, or why I had to do with this way for the bonus features, but not for the regular episodes. Looks like I just may be in business. Thanks again for your help.
    --Londo Mollari, B5
  14. Hi again. Pretty strange, eh? The episodes play with audio, and the extras don't. I think I have an idea why. When you just play a Vob, you don't get to choose the audio stream, if there's more than one. Say you have a set of movie Vobs on the hard drive. You play one of them and you might get the movie dialog. You play a different Vob and you might get the Director's Commentary. Maybe the same thing is at work here. There are 2 audio streams, but one is a dummy, a blank one. This might happen if there are 2 PGCs in the same VTS, 2 different extras in the same VTS. One might have, for example, DD 5.1, and the other DD 2.0. So, each will have 2 streams, one stream for each of the 2 different kinds of audio, but only one has any sound. You can confirm this theory by playing the original DVD in PowerDVD or something like that, or even in the standalone. It'll play with audio, because the IFOs direct it to the right audio stream, but you'll be able to choose another audio stream, using the remote for the standalone, or changing audio in your software DVD player. The other audio will be soundless. Just a theory.
    So I'm guessing that it'll convert just fine in AutoGK, but make sure, if it shows 2 audio streams, that you choose the correct one. So there shouldn't be any need for you to do any audio converting or muxing yourself. Glad to help. Sorry for some of my wrong guesses. It's kind of hard to diagnose things sometimes from thousands of miles away.
    The bonus feature (in this case, it was a blooper reel) did convert just fine in AutoGK, so it looks like I'm in business. I didn't see any other audio tracks listed when I loaded it into AutoGK, but then I wasn't looking for them so maybe I missed them. Thank you again for taking the time to help we work out these wrinkles, I am tremendously grateful. I'll be doing an entire disc tonight, both extras and episodes, instead of just samples now that it looks like I've got things working.
    On another, more logistical note, I found the post on here about doing batch decrypting with DVDdecrypter using a .bat file and command line mode, so that looks like it will help the process along. The only thing I worry about is what I have noticed in AutoGK that when you load in the IFO, it asks you exactly which PGC it should be dealing with, and I can easily foresee myself forgetting or mixing up which one is which. I'm thinking maybe the best way to try to avoid that is to include the VTSand/or PGC numbers in the name of the file folder to which you decrypt each vob. Either that, or I'll be writing it all down on little scraps of paper that will inevitably get lost or mixed up. Do you have any particular method for avoiding this problem?
    --Londo Mollari, B5
  16. If there are multiple PGCs in the same VTS, I name the folders to which I decrypt the vobs as, for example, 1-1, 1-2, 1-3, etc. That way if AutoGK asks which PGC I'm converting, I can refer to the name of the folder.
  1. Ripping a multi-episode DVD
    By scoopyx in forum Newbie / General discussions
    Last Post: 21st Dec 2009, 22:55
  2. I have a problem with ripping multi-episode DVD
    By jemping in forum DVD Ripping
    Last Post: 27th Oct 2009, 11:42
  3. Replies: 7
    Last Post: 5th Aug 2009, 13:19
  4. Replies: 11
    Last Post: 5th Aug 2008, 09:32
  5. Easiest way to convert episodes from a dvd to single episode files?
    By Pj10 in forum Newbie / General discussions
    Last Post: 21st Dec 2007, 21:42
