I have an NTSC VCD stream that I want to covert to PAL VCD stream and I was using TMPGEnc and the output PAL stream was very jerky. Does anyone know how to fix this problem?
Process required:
- 3:2 pulldown removal (which changes the framerate from 29.97 --> 23.976)
- de-interlace (optional)
- resize video to framesize of 352x288
- speed up (video AND audio) to 25 fps
When the audio is sped up (by approx. 4%) the pitch will sound funny. You could speed up the audio while maintaining pitch, but I reckon that the end result is even worse (so it's up to you).
As far as I know, I've only really done this process once (but from 30 fps AVI to 25 fps MPEG, not MPEG --> MPEG). The end result is quite reasonable.
I don't know if you can do it all in one step, but if you could, you would probably use AVISynth with a script.
Mind you, encoding from MPEG to another MPEG will absolute kill the quality.
Regards.
Michael Tam
w: Morsels of Evidence
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 11:06 -
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 16:34 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 14:29 -
What Is The Good/Correct Method to convert from 25fps into 29.97fps..
By hypershade in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2009, 07:49
Statistics
Newest guides
Latest tool updates
New media comments
