VideoHelp.com Forum
  1. Member Wile_E's Avatar
    What is the analog equivalent to 0db digital? I have an ADVC-300 that I use to capture VHS to DV. It has some controls to boost audio input. I'm finding that many of my tapes are peaking at 0-3db in analog, and -12db in digital. This is with default settings in the "picture controller" software.
    I know that anything over 0db digital is clipping, so I only boost the audio to -3db digital. Is this an acceptable practice in the real world when converting analog audio to a digital format? Or should analog audio remain at a lower db on the digital scale?
    The ADVC-100 has no audio adjustments. So I'm curious what level it peaks?
  2. Member anubis13's Avatar
    Analog usually peaks around -6 db. anything several dBs under the red should work fine
    I have the ADVC-100 and it usually peaks at -12db no matter what I hook up to it.
    Analog runs -6 to -10 db lower than digital. it will not "clip" at -0db but usually distort.
    don't just rely on virtual VU meters. use your ears.
    drink up....the world's about to end
  3. Member edDV's Avatar
    In digital, 0dB is the clip point. 50% of peak value is - 6dB. 25% of peak value is -12dB. -6dB is often used as a working peak level to allow headroom for overshoots.
    16bit audio has a maximum dynamic range of -90dB. The actual noise floor is determined by the equipment (~ -70dB typ for prosumer camcorders).
    Some refs:
    http://www.creativemac.com/2003/02_f..._dv_levels.htm
    http://www.sounddevices.com/tech/pd150.htm
    http://www.jimprice.com/prosound/db.htm
    http://www.equipmentemporium.com/audiohi8.htm
    http://www.kiva.org/about
  1. digital 2 analog audio
    By downriver in forum Newbie / General discussions
    Last Post: 11th Dec 2010, 18:45
  2. analog to digital tv tuner
    By bkapca in forum Media Center PC / MediaCenters
    Last Post: 14th Jan 2010, 12:32
  3. Replies: 3
    Last Post: 27th Oct 2009, 21:56
  4. Digital to Analog chips
    By j_me in forum Newbie / General discussions
    Last Post: 5th Oct 2009, 19:03
  5. Analog vs Digital TV
    By J. Baker in forum Newbie / General discussions
    Last Post: 10th Jan 2009, 03:21
