VideoHelp.com Forum
    The eagerly awaited Toast 7.0.2 update can now be downloaded from Roxio's software updates site. It also includes updates to CD SpinDoctor and Motion Pictures. Here's the list of what's changed:
    -Disc spanning now prompts to re-burn if a failure or error occurs while burning a single disc.
    -Includes Roxio Restore v1.0.2 which resolves an issue related to not finding the index file during restore. This version is automatically added to the Application Support/Roxio folder on your hard disk when you run Toast. All existing spanned discs will detect and use this newer version during the restore process.
    -Canceling burning while disc spanning now prompts for confirmation.
    -iMovie 5 projects with chapter markers are now correctly burned to DVD.
    -Media Browser now correctly displays iTunes playlists and iPhoto albums stored in Folders.
    -Media Browser now correctly displays titles and chapters from CPRM protected DVD-VR discs.
    -Video Export now properly supports MPEG4 and H.264 for iPod video.
    -Resolves crashes decoding and exporting DivX video files and exporting for PlayStation Portable.
    -Audio Export now properly supports MP4 for PlayStation Portable.
    -Audio Export OGG and FLAC options are now properly enabled.
    -"Toast It" desktop burning menu now correctly sends VIDEO_TS folders to the proper disc format.
    -"No Menu" style option now works correctly for Music DVDs.
    -Auto-play and continuous play options now work correctly for DVDs with a single image or single music track.
    -GIFs and TIFFs now correctly work as background images for data discs.
    -Resolves crashes that occur while moving or deleting files during the burn process.
    -Resolves an issue where burning multiple copies of a DVD would not complete correctly.
    -Displaying the recording sheet is no longer delayed if media is inserted while the record button is pressed.
    -The project estimation gauge is now more accurate for dual-layer media.
    -Resolves an issue where menus could become disabled if the screen saver activates while burning a disc.
    -Includes Deja Vu backup scheduler v3.2.1 which resolves numerous issues (see http://www.propagandaprod.com/releasenotes.html for details). Deja Vu is installed by the Toast Setup Assistant which runs the first time you launch Toast and can also be selected from the Help menu.
    -A "More DVD Menu Styles" link has been added to Help menu.
    CD Spin Doctor v3.0.2:
    -Resolves an issue where auto-define tracks would incorrectly detect splits.
    -Desktop recording widget can now be installed directly from the New Recording dialog.
    -Resolves an issue with crashes when playing back 192 kHz/24 bit audio files.
    -Resolves an issue from crashing due to rapid starting and stopping of audio playback.
    Motion Pictures v2.1.1:
    -Auto-rotate now correctly works with motion presets and when new pictures added.
    -Motion editing rectangles now properly support portrait images.
    -Group layouts now properly support portrait images.
    -Rendered video now properly falls within TV-safe areas.
    -Podcasts are now filtered out of audio list.
    -Full screen preview and motion preview correctly revert back to main window when finished.
    -Full screen preview is now blocked while encoding.
    -Includes correct Help files for English, French, German and Japanese.
  2. Master of my domain thoughton's Avatar
    And downloading it is a right pain in the butt. Click here, click there, type in name and password, enter email, click here, click there, click here, click yet again, choose what product, click, click, click. Finally you get the flippin file.
    Tim Houghton
    WebsitePhotography
  1. ffmpegX serial code - it never arrived!
    By mediajunkie in forum ffmpegX general discussion
    Last Post: 28th Aug 2009, 17:12
  2. Replies: 1
    Last Post: 30th Jan 2009, 23:46
  3. Santa has arrived on site.
    By gll99 in forum Feedback
    Last Post: 6th Jan 2008, 17:27
  4. Corrupt Video Files - Doomsday Arrived
    By Quarkrad in forum Newbie / General discussions
    Last Post: 28th Nov 2007, 10:15
