VideoHelp.com Forum
    Ok I have just recently finished resizing and converting a file that is the same exact video (divx3) and audio (lame) codecs that was in the previous file which worked well burned on the same exact cd on my dvd player however this new conerted file of the original refuses to work. It will show up on the dvd menu but soon as I select it the screen simply flashes and refuses to do anything
    I did a side by side comparasion with GSpot and all that is different is the bitrate on the new file is lower then the other file. Both of these codecs in the same exact fashion were working yesterday on the player perfectly fine.
    The cd is a cd-rw which while burning in nero 6 I have finalized ruling out the possibility that burning it might be the problem. Does anyone have any ideas
  2. Member Krispy Kritter's Avatar
    What player are you using to play the disc?
    Google is your Friend
    JVC XV-NP10
  4. Member Krispy Kritter's Avatar
    OK, so you have 2 video files. The original file is playable in your player. The smaller file that you created is not.
    If you are using the latest version of gSpot, it will also show you if GMC or QPEL is being used in the file. This causes trouble in some players.
    Other than that, what tool did you use? Sounds like something is wrong with your conversion process. Does the video play on your pc?
    I have the latest *stable* version here is the statistics from GSpot:
    size: 147 MB (or 151,064 KB or 154,689,536 bytes)
    video codec// 4cc: "div3" name: "DivX 3 Low-Motion"
    stream type a/v intervele //  Type: "OpenDML AVI"  IMRR: "1.00"  I/l "1 vid frame (42 ms)  Split: Yes"
    comments: vdubmod 1.5.1 build 2540
    audio codec// name: "0x0055(MP3) ID'd as MPEG-1 Layer 3"
    bitrate: "92 kb/s (96/ch, stereo) CBR "  Fs: "48000 Hz"
    direct show render//
    video src// 4cc: DIV3
    audio src// MPEGLAYER3 (MP3) (0x0055)
    video path// (S) --> AVI Splitter --> DivX Decoder Filter --> (R)
    audio path// (S) --> AVI Splitter --> MPEG Layer-3 Decoder --> (R)
    rendering succesful//
    The video plays fine on my computer.
  6. Member Krispy Kritter's Avatar
    When you played the file on your pc, was it the copy on the HD or the copy on your burned disc?
    oh that fixed it
    turns out the disk recently got messed up. Thanks for birnging it too myattention. PROBLEM SOLVED
  1. Problem with Media Player Codec Pack
    By brassplyer in forum Software Playing
    Last Post: 12th Jan 2012, 06:39
  2. How would you describe the difference between a CODEC and a FORMAT ?
    By Bansaw in forum Newbie / General discussions
    Last Post: 2nd Feb 2011, 15:42
  3. DVD Title display on player LCD screen
    By DRP in forum Authoring (DVD)
    Last Post: 9th Mar 2010, 12:36
  4. Replies: 2
    Last Post: 27th May 2009, 22:48
  5. Codec issue for my clients playing a DVD I produced..
    By plemal in forum Newbie / General discussions
    Last Post: 11th Mar 2008, 16:34
