With Windows XP?
Want to use it with GB-PVR to change channels on Cable-Box.
My main goal is to have the Channels Change on my Digital Cable Box,When I set a Recording.
Anyone have any suggestions on a Remote that will do this?
Thanks..
I wouldn't assume. Why not ask the guru?
http://forums.gbpvr.com/showthread.php?t=11542Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Been there.
Back to the Main Question.
Will a Microsoft Remote Control for Win Media Center work with (Win XP)?
Originally Posted by canadateck
With or Without GB-PVR.
If your question is "Will the Microsoft Remote Control (for MCE) work with Windows XP (without MCE)" I'm pretty sure the answer is yes. Before I loaded WMC, I purchased 2 remotes and the IR transceiver. I still use them with Meedio and Media Portal. However, I never tried to use the included extension of the IR remote for changing cable box channels. But I am pretty sure it can be programmed to do so.
All of the media center remote controls that I have seen require MCE.
Check out "IR Blaster". Best to do it in the context of the software you want to use or you are into driver writing to make the hardware functional.Recommends: Kiva.org - Loans that change lives.
Media Center + Multiple TV's + Touchscreen Remote
By jc0r in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2012, 21:07 -
Which remote control with IR blaster to use with Windows 7 Media Center?
By usually_quiet in forum Media Center PC / MediaCentersReplies: 5Last Post: 1st Sep 2010, 18:59 -
WIn. Media Center (16:9 --> 4:3)
By Throb1231 in forum Media Center PC / MediaCentersReplies: 7Last Post: 27th Jun 2010, 12:58 -
Looking for a good Media Center Program with Remote....
By remission in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2009, 13:09 -
vista media center remote
By skierrob in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 02:33
