hey im haveing this crazy problem when i press enter to render some files it well the whole workspace starts and goes fine un til it gets like to 7.3% and then my pc shuts off and on top of that when i open taskamanger it says my cpu ussage is up to 99% wile im runing premire pro
please help
by the way if this helps any im have 1gig and half ram amd athlon xp 2.2gz thanks in advance
Thread: Premire Pro Restart
How long has it been running before it shutdown ? (7.3% means nothing - length of time is more important)
Could be overheating, could be premiere.
If you are rendering, I would expect PP to use 99-100% of the CPU, and frankly I'd be pretty pissed off if it didn't. That just means it is utilising your machine fully, and not wasting power. That said, running at that level will make the system run hotter, hence my first point about overheating.
Simple tests
1. Next time it shutsdown, start it up and go straight into the bios. From there you should be able to find the CPU temperature. It is debatable exactly how accurate the figure might be, but it is a start. Post the numbers back here.
2. Pull the covers off the PC and point a stadard desk fan into the case. Leave it running and try to do the render again. See if you get any further.
HEY check this out i think it was overheating i did not put an desktop fan i put an big as house fan one of those that u keep in the windows u know the one u buy at walgreens lol then i selected a littile area on the time line and render it and what do ya know it works before it woudent even get pass 7% but it dose now ill try the rest and tell ya lol this is crazy thank god for walgreens ill let ya now pimp whats going on peace out pimp and thank you can i ask why dose it do that
it overheats because you are maxing out the processor for hours on end. The harder it works the hotter it gets and stays. The heat accumulates in the heatsink and the heatsink/fan can't draw it away fast enough so the temps keep rising until poof! thermal protection shuts you down. My p4 3.06ghz did that and funny you should mention it because i also used a big box fan to keep it cool until my new heatsink came in.
Ultimately though if you intend to do alot of video encoding you should look into getting a better heatsink/fan for your cpu. The stock one just doesn't cut it sometimes. I bought the xp-90 heatsink/fan combo and it dropped my temps at full loads by 30 degrees F!
You may also want to check into getting some good case fans to suck the heat out of your case and keep the ambient temps down if you don't already have good case fans. It will be an initial investment of probably about $40 bucks but could save you loads in the long run.
OK thanks for all the help u guys i mean u guys rock it is overheating like u guys said and thanks for all the help i would like to thank the guy above fore the example and the u both for the solution
Premire Pro CS5 Export does not work with iPhone Anymore
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 16:38 -
error+restart while loading Premiere Pro
By pixiecate in forum EditingReplies: 1Last Post: 22nd Oct 2009, 14:08 -
best export setting in premire pro CS3 for youtube
By yunakokimama in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 17:09 -
how to export MPEG4 from Premire Pro 2?
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2008, 00:36 -
adobe premire pro CS
By pantsdavies in forum Software PlayingReplies: 58Last Post: 15th Dec 2007, 20:27
