I'm trying to make a dvd of an avi with 25 fps. I also need to add the subtitles. I have the subtitles file but it's formated for 25 fps
I made the dvd folder and the subtitles work fine but I won't be able to play in my player unless i convert to 29.97
if I convert the frame rate when i encode the dvd, the subtitles are off.
can i convert the frame rate of the dvd folder or is there a way I can have it place the subtitles properly based on the frame rate conversion?
You may use SubSyncX to change the subtitles framerate.
thanks!
Does anyone know where to download SubSyncX?
the link on macupdate doesn't work, can't seem to find it
SubSyncX.sit (732 KB)
Case,
Thank you very much for posting the link to this! I've been searching for an hour and a half!
Jim
How to convert any video to AVI or MP4 or MKV with burned in subtitles
By Baldrick in forum User guidesReplies: 31Last Post: 8th Jan 2012, 07:04 -
need software to convert video files that have different frame rates
By snafubaby in forum Video ConversionReplies: 2Last Post: 7th Mar 2011, 02:33 -
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 11:50 -
Trying to convert World Cup game to DVD, have a ? about frame rate
By Roge in forum Authoring (DVD)Replies: 8Last Post: 10th Sep 2010, 06:06 -
Is there a program that can safely convert variable frame rate videos?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 17th Jul 2007, 20:01
